High Quality mp4 s are muddy in VS2020 -SOLVED-
cybernick
Video Card: GTX 1060
Hard_Drive_Capacity: 1TB nvme
Corel programs: Video Studio 2020&2021 Ultimate
Post by cybernick »
has anybody faces such an issue?
Some of MP4 files (captures with OBS or Geforce experience) which are 1080p or 1440p and can be view extremely crisp in windows default player are muddy in VS2020. Not only in preview screen but also in render with the same specs of the initial file.
cybernick
Re: High Quality mp4 s are muddy in VS2020
Post by cybernick »
Anyone please?
Can it be something with codec. Should I install a codec?
I consider to make a clean reinstall. Will it be enough to install sp4 file?
Also mine is update version should I need to install VS19 first?
cybernick
Post by cybernick »
I did a repair installation. No solution.
To explain what I mean I have attached a zip file with two files.
The orijinal high res MP4 file and the rendered file with exactly the same specs in VS2020. You can see what VS2020 did to the file.
What do I miss. Please suggest.
https://drive.google.com/file/d/1Va6_Nq ... sp=sharing
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
Indeed it's crap as I always said. VS's mp4 is not good for animation. This is why I use only WMV when I have animation segment.
Panasonic X900m, VXF1
cybernick
Post by cybernick »
Was is always like this? Because it was way better in early versions.
Or I did something and works like this?
Hi Nick
I was a little concerned in comparing the original properties, I used Media Info
The video is using a variable frame rate which Video Studio does not get on well with, sometimes that is
There was also a reference to Pal which in its self not a problem but then the frame rate of 60 would indicate NTSC, so I was a little confused and did not understand if that would be an issue
With Pal / Ntsc in mind I set my 2020 to NTSC, F6 – Preferences – TV System - rebooted the program
Also From F6 – Preferences – Edit Resampling Quality to Best
Imported the original to the timelines which prompted for a match of the Project Properties as :-
MPEG-4 Files
24 bits, 2560 x 1440, 60 fps
Frame-based
H.264 High Profile Video: 15606 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 96 Kbps
Share – Same as First Clip to create a new video file which looks ok, lets say I can read the writing on the map
Better to use VLC Media Player, or any player other than VS
Post Updated to add sample video
I have not used Google Drive for a while, hopefully this link works
https://drive.google.com/file/d/1m6251E ... sp=sharing
I also changed/deselected the F6 Preferences – Edit – Apply Colour Filter, did not seem to change anything although a subtle change is difficult to compare.
At the moment the colour filter is set to NTSC, even though I am in Pal UK
cybernick
Post by cybernick »
Can you please upload the file . I will also try the same.
Hi Nick
Just updated the post, did not realise it would display there, had thought a download link?
cybernick
Post by cybernick »
Ok I tested as you mentioned. No big change. Still VS2020 kills the quality of the media. Check this out
https://drive.google.com/file/d/1iOb-Ez ... sp=sharing
As you say no change there,
Did you manage to download the Lata Cybernic.mp4 sample on my google drive.
cybernick
Post by cybernick »
lata wrote: Mon Jan 18, 2021 1:44 pm As you say no change there,
OMG your render is way better. How you manage to do that. Mine is still garbage.
As first video or as the project the output is the same buddy video.
Do you have any codec pack installed. Can it be something related to that?
Just tried using Share – Same as Project Settings, this took much longer to render as though Smart Render is not being used, I think that may be the case.
Same good results, difficult to say if Same as First Clip with Smart Render is better quality or not?
Step by step
First is your program installed as Pal or Ntsc, I assumed Pal?
1 / Settings Preferences F6 – Set TV System to NTSC
2 / Edit Tab – Set Resampling Quality to Best
3 / Performance – Smart Proxy is deselected,
OK to close the panel
4 / Reboot the program.
5 / Add the original video allowing the Show Messages to change/match the Project Properties
6 / Share – top left for Same as project properties, I changed that to Same as first Clip.
I will revert my program back to Pal to see if I can render the poor quality again
Ok I have been through all my settings changing those one at a time and still unable to render a bad video
I have also checked Smart Proxy files as that has caused some quality issues
Maybe I need to reboot the computer to clear any cache files, strange that I can no longer render a bad one?
cybernick
Post by cybernick »
lata wrote: Mon Jan 18, 2021 2:01 pm Just tried using Share – Same as Project Settings, this took much longer to render as though Smart Render is not being used, I think that may be the case.
Step by step
Iata,
I did exactly as you mention. First of all My Apply color fileter (pal/ntsc) was deselected. I choose NTSC anyway. And I exported as "same as first clip". No chnage. Terribly bad output.
I managed to get somehow usable output with mp4 custom share setting. With the following settings. Do you also use Ulead Mpeg-4 vio Driver?
As you can see I need to boost the bit rate to 65000 which caused the file size to become 300 MB.
Yes the Ulead Mpeg-4 vio Driver? is available when setting the properties
When I first rendered the original video this morning the resultant video was as bad as your sample
I then tweaked my program settings to use NTSC thinking there may be a Pal / ntsc conflict
Then all renders were very good
I have since reset my program to my original Pal settings and still render good video
I have also booted up 2019 that should use the same setting as 2020, rendering using 2019 was good quality
so the first render was very poor, now I am completely confused as i can no longer replicate the poor video.
