Slowing down for easier cutting?
Annclarke
Hard_Drive_Capacity: Toronto
Post by Annclarke »
Sorry if this has been asked already- it's difficult to find. I'm trying to edit a video for the first time and it's tricky to make cuts with the video playing at normal speeds. I find myself anxiously trying to pinpoint the right place and the video has already moved past me! Is there a way to slow down playback just for editing purposes (without changing the speed of the final clip)? Appreciate the help.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Slowing down for easier cutting?
Post by asik1 »
How do you cut?
you can hit S
Panasonic X900m, VXF1
pogonips
motherboard: Lenovo Legion Y740-17IRHg
processor: Intel Core i7-9750H 2_60GHz
Video Card: NVIDIA GEFORCE RTX
Hard_Drive_Capacity: 1_5 TB
Corel programs: Corel VideoStudio 2020 Ultimate
Post by pogonips »
I find it more efficient to use Avidemux (free video trimming utility) for initial cutting/trimming of video files. You can scroll the scrubber or play your clip until you get to the right area and then move a frame at a time, or a key frame at a time to decide where to cut. Saving the trimmed files seems to be much faster than rendering in VS too. Then I load the trimmed files to VS for more detailed work like effects, transitions, etc.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Your profile doesn't indicate what version of VS you're using, but splitting/trimming your clips is basically version invariant.
Annclarke wrote:it's tricky to make cuts with the video playing at normal speeds. I find myself anxiously trying to pinpoint the right place and the video has already moved past me! Is there a way to slow down playback just for editing purposes (without changing the speed of the final clip)?
The way that you're trying to split/trim your clips is not the norm. Using the VS properly , you can split/trim your clips with frame accuracy (see following extract from the user guide). The user guide can answer many basic questions.
Annclarke wrote:Hard_Drive_Capacity: Toronto
I know that Toronto's population is some 6M people, but I'm curious how many gigabytes does Toronto have?
pogonips wrote:I find it more efficient to use Avidemux (free video trimming utility) for initial cutting/trimming of video files.
There is no obvious benefit from using Avidemux as VS, like any NLE, can readily split/trim your clips. It seems that you're just adding an unnecessary step to your workflow.
tletter
