Tightening up the Space (Toolbars) at the Top of the Screen...
suplex
- motherboard: ASRock ATX DDR3 1600 AMD AM3+ 970 PRO3 R2-0
- processor: AMD FX-8320 CPU [8x 3-50GHz-8MB L3 Cache]
- ram: 8 GB
- Video Card: NVIDIA GeForce GT 730 - 2GB
- sound_card: 3D Premium Surround Sound Onboard
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Acer SB220Q 21.5" Full HD (1920 x 1080)
- Corel programs: Pain Shop Pro 2021 Standard
Hello Everyone,
I am new here, but I have been using Paint Shop Pro since it was version 7 (back when the versions were numerically numbered before they changed to using the year). I received PSP 2021 (Standard Edition) for Christmas this year, love it so far, and I am configuring it so that it matches the layout I was using in my previous version (I love the "Workspace" that you can create, save, and load on another version of the software).
What I am trying to do now, is tighten up the space at the top (I will include a screenshot, with some added text to explain better) where you would normally put Toolbars. The Toolbars that I use, by the way, are: "Standard", "Status", & "Tools". On my last version of PSP, using the 2019 version, I had only two bars visible at the top, with no spaces between them (top to bottom), and my current PSP, 2021, there is an empty bar that I would like to remove.
Here is the screenshot which better explains it. If anyone may know how to do this, I would appreciate your assistance.
Thank you.
Thank you.
Re: Tightening up the Space (Toolbars) at the Top of the Screen...
Hi suplex, welcome to the forums!
That's kinda odd. Row 2 should get automatically vanish since there is nothing on it. You can check the View -> Customize | Toolbars dialog to see if there is an empty toolbar active in there, though it should show a handle on row 2 if there was. In that dialog you can try to reset all toolbars, or even reset the whole PSP by holding down the Shift key the next time you launch it (make sure you save your custom workspaces first, so you can load them back after the general reset).
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Try File/Reset/Workspace
You may also drag the toolbars and Menubar manually.
suplex
- ram: 8 GB
I will give resetting the Workspace a try, but dragging them manually hasn't gotten me anywhere yet.
suplex
- ram: 8 GB
Kathy_9
- Hard_Drive_Capacity: 2TB
In that case, try option 2 on the following link: https://forum.corel.com/viewtopic.php?f=56&t=67616
Jean-Luc
That's correct.
If no workspace is selected, it will stay grey. Click on Complete and "Reset Workspace" will be available.
suplex
- ram: 8 GB
Interesting. I did that (Clicked on "Complete") and it actually tightened up the space of which my original concern was. But when I reloaded my saved Workspace, it put that Row in the top that I can't get rid of again (reference my original picture where I labeled three "Rows").Click on Complete and "Reset Workspace" will be available.
Looks like I will probably have to wait until I have more time and re-build my workspace how I like it, after selecting "Complete" (to get rid of that row) and just do it that way. I truly wish there was just something I could fix, if I could just figure out what it could be.
You don't think it's possible that it's happening because I have the Standard version of PSP 2021 and not Ultimate, do you? I used to use Ultimate and then realized there is stuff in that version I really don't use, so I decided to save some money with Standard this time.
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
The PSP program is the same in standard and Ultimate. Just more extras like the Creative Content stuff and a few extra filter type programs available.
JoeB
Using PSP 2019 64bit
JoeB
Hi suplex,
did you try my suggestion to check out the View -> Customize | Toolbars dialog for any bogus toolbars in there? I had a similar issue in the past (with PSP 2020 or 2019, I don't remember) but I think I had caused it when I loaded in the newer version a custom workspace created in an older version. No matter what I tried I couldn't fixed it, so I ended up re-creating my custom workspace from scratch in the newer version of PSP.
I had made a post here, and Levi suggested that probably the registry got screwed up. Since there were many bogus toolbars that wouldn't go away, I figured it would be wiser to uninstall the newer version of PSP, install it again and create the workspace from scratch.
suplex
- ram: 8 GB
Hello. You know something? I wonder if it's giving me trouble because I left my older version on my computer and installed the new one, which essentially has both versions available. My old one was PSP 2019 Ultimate, and the new is PSP 2021 Standard and I did take a Workspace from 2019 Ultimate and used that to configure 2021 Standard. I wonder if I had uninstalled 2019 first, then did 2021 if the Workspace would have worked correctly? I will try your suggestion (to see if there are bogus toolbars floating around) and see how that goes. Otherwise, when I have time to dedicate to it, I will be building it from scratch if it has to come down to that.migf1 wrote: ↑Tue Jan 05, 2021 1:44 pm Hi suplex,
suplex
- ram: 8 GB
Well, I finally just decided to reset it and build the workspace over again, but now I have a new question (I will include my question in a screenshot), and it's about how you get information on the very top bar where it says: "File, Edit, View, etc...". If you go into Customize, you can pull things out of that bar, but how do you get them back in? Here is my screenshot explaining what I would like to do now.
Kathy_9
I'm confused. You say you accidentally removed palettes but palettes is still there in your screen shot (left of User Interface).
Hi again suplex. As Kathy pointed out, your screenshot shows the Palettes menu being in place already. In any case, you can always reset the default menus via the View -> Customize | Menu | Application Frame Menus [Reset] button.
As for multiple PSP versions installed on the same computer, it is fine (many of us have it like that). The issue I described was due to the fact that I loaded into a newer version of PSP a custom workspace created in an older PSP version.
That may not be the case for you, but if you cannot disable any bogus toolbars from within the View -> Customize | Toolbars dialog (or you cannot Reset all Toolbars to their default from that dialog), it is probably a good idea to fully uninstall PSP 2021, then install it again and create your custom workspace from scratch just for PSP 2021.
In my experience, it is better to re-create any custom workspaces from scratch, instead of loading ones made with earlier versions of PSP.
suplex
- ram: 8 GB
You are correct, I took the picture when I still had "Palettes" in the top toolbar. I saw instructions on how to reset that to get it back to original and they worked great.
