This is a new scene not found in either of your previously posted files of 826MB and 383MB in size, so it'll have to be assumed that the video properties are the same and that the original video is of good quality.mangurian wrote:https://drive.google.com/file/d/1T126EU ... sp=sharing
The scene is tricky one with many fine details caused by the tree branches so you can't throw away data and expect a decent looking rendered file. However, that is exactly what you did by reducing the data rate by half from 34,982kbps to 15,104kbps. The data rate issue was mentioned to you in previous post.mangurian wrote:Here is one of my results. Not the worst.
This was already posted, but to repeat, using the "Same as First Video Clip" option will properly set the project properties.mangurian wrote:If someone would be kind enough to post some successfull parameters, I would be happy to try them.
It seems that you're so frustrated that you're not bothering to read and take-in what's being said to you. Perhaps you should reread the advice that was given to you with an open mind this time.mangurian wrote:I let frustration get to me.
tletter
