Sputtering Audio
- kdog509adam75+
- motherboard: Gateway H57M01
- processor: 2_93 gigahertz Intel Core I3 530
- ram: 6072 Megab
- Video Card: NVIDIA GeForce GTX 650 Ti
- Hard_Drive_Capacity: 2500 Gi
- Monitor/Display Make & Model: VIZ E280-B1 [Monitor] (27.7"vis)
- Corel programs: PSP 7.04, PSP 2021, VS PRO X4, VS 2020
Sputtering Audio
When I edit video in Video Studio Pro 2020, the audio stutters terribly. I'll open a video and select Multi Trim. I'll mark the cut in point where I want the edited video to begin. Then hit play to run the video to the point I want to mark the cut out. During that time, while the video is playing the audio sputter or stutters, hard to explain it any other way. Is that normal?? Seems to me it's not, but......When video is played normally, the audio is fine as is the edited video clip after I'm done trimming. It's only during the actual trimming process that the audio goes a little catty wonkers.
Re: Sputtering Audio
If you are using Smart Proxy files then it does appear that those are not applied to clips when using MultiTrim
Several posts refer ---- this one shows a response from Corel Support
https://forum.corel.com/viewtopic.php?p ... #p379290is
You do not say what type of video you are using nor if you are using Smart proxy
- kdog509adam75+
- ram: 6072 Megab
I'm just editing GoPro video from some of my motorcycle rides. I'm not sure what Smart Proxy is.
- kdog509adam75+
- ram: 6072 Megab
OK, I found Smart Proxy in my settings and turned it on, but it didn't make any difference.
Pepi
- motherboard: ASUS TUF Z270 MARK 1
- processor: Intel i7-7700K
- ram: 32GB
- Video Card: AMD Radeon RX 5700 XT
- Corel programs: VideoStudio 2022; PaintShopPro 2022
Could it be so that the audio codec on the video is something not so standard? GoPro is still quite big vendor that very much unlikely so. Have you tested with other formats on GoPro or a shorten videos? If you made own video with sound, can get the same problem when you try to trim that then?
What are your video's properties: (Right click clip on the video track and select properties)
Have you monitored your CPU usage while sound is breaking, is that higher than normal?
Don't Panic
Don't Panic
Just turning on Smart Proxy is not enough, Smart Proxy files have to be createdkdog509adam75+ wrote: ↑Sun Dec 13, 2020 3:54 am OK, I found Smart Proxy in my settings and turned it on, but it didn't make any difference.
First view Preferences (F6) – Performance tab, tick enable Smart Proxy
I allocate a folder on my D Drive to hold the proxy files, keeping my C drive clean. your choice
Back to the time adding any HD video will start the proxy process, Settings Smart Proxy Manager – Queue Manager will show the progress, once complete the clip will show a small icon as attached image
If the clips are already on the timelines then we have to manually create the proxy file, right click the clip for Create Proxy files, can be done from the library clip.
They do take a while to create but once done should improve timeline playback.
Just for the record, the GoPro -- at least the latest Hero 9 Black and other recent versions of the camera -- use MPEG AAC audio which is of course quite standard. I just bought a Hero 9 Black last week, so could check that quickly.Pepi wrote:Could it be so that the audio codec on the video is something not so standard? GoPro is still quite big vendor that very much unlikely so. Have you tested with other formats on GoPro or a shorten videos?
- kdog509adam75+
- ram: 6072 Megab
OK guys, got it working fine now. Thanks for all the help, you all rock.
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Can you please post what you found and how you solved your problem? It would help others in the future.
