Create a custom crop preset by aspect ratio?
loiswakeman
Post by loiswakeman »
I have several presets of fixed pixel width/height saved, but I want to create a 2x1 preset that will, like the 2x3, 4x5, square, etc, automatically resize itself to the width of the current image. Is there any way to do that?
(I can workaround by specifying pixel dimensions, but I use this aspect ratio a lot, and a preset would be neat. I could also set up similar for social media images e.g. instagram stories.)
Thanks in anticipation.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Create a custom crop preset by aspect ratio?
Post by LeviFiction »
Yes, it just takes a small edit of the preset once you've made it. There is a parameter called "AutoFit" that I don't know how to set inside of the UI in PSP but is a very simple thing to change in Notepad. You can do this any number of ways. I'll list two of them here.
Option 1: Create the preset directly inside of PSP
1) Open the Crop tool
2) Turn off "Maintain Aspect Ratio"
3) Set Pixel Dimensions to 200x100
4) Turn On "Maintain Aspect Ratio"
5) Click on the "Presets" button next to the checkmark button on the tool options palette
6) Click the "Save Preset" button on the drop-down and give it a name like "2 x 1"
7) Go to your Presets folder (e.g. c:\users\YourUserName\Documents\Corel Paint Shop Pro\ Your Version \ Presets
8) Open "Preset_Crop_2 x 1.PspScript" (or whatever you called it) with Notepad or a similar code editor.
9) Change the value of "AutoFit" from "False" to "True"
10) Save
Option 2: Copy and Edit an existing Preset and change the size
1) Go to C:\Program Files\Corel\Corel PaintShop Pro 2020 (64-bit)\Languages\EN\Presets (or whatever version of PSP you're using)
2) Find "Preset_Crop_Square.PspScript"
3) Copy it
4) Go to ":\users\YourUserName\Documents\Corel Paint Shop Pro\ Your Version \ Presets"
5) Paste it into this folder, and rename it from "Preset_Crop_Square.PspScript" to something like "Preset_Crop_2 x 1.PspScript"
6) Open in Notepad or a similar code editor
7) Change the 'CropRect' value from "((0,0), 100, 100)" to "((0,0, 200, 100)" <- These are pixel dimensions the last two values are width and height.
8) Save
loiswakeman
Thank you so much - I'm off to try this now :)
Edit - works like a charm. Can't tell you how grateful I am for this timesaver!
