Just started with VS and I notice when rendering that it's only using a bit less than 25% CPU.
My previous editor (and Handbrake) utilise nearly 100% when rendering.
Is there some setting I haven't found to make it use more of the CPU and thus go a bit faster?
Steve
Rendering only using part of CPU
cybernick
- Video Card: GTX 1060
- Hard_Drive_Capacity: 1TB nvme
- Corel programs: Video Studio 2020&2021 Ultimate
Re: Rendering only using part of CPU
It depends of the codec and/or source file you are using. For example for WMV output GPU almost never used.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
VS isn't able to fully leverage available hardware as you've seen. You could try playing with VS's hardware performance setting, e.g. hardware acceleration or running VS at the Realtime priority level, although these can result in VS crashing.sclg wrote:Just started with VS and I notice when rendering that it's only using a bit less than 25% CPU.
tletter
sclg
- motherboard: Asus mobo
- processor: Intel i5
- Video Card: Om mobo
- Hard_Drive_Capacity: Lots
- Corel programs: VideoStudio Ultimate 2020
Thanks.tletter wrote: ↑Wed Nov 25, 2020 6:20 pmVS isn't able to fully leverage available hardware as you've seen. You could try playing with VS's hardware performance setting, e.g. hardware acceleration or running VS at the Realtime priority level, although these can result in VS crashing.sclg wrote:Just started with VS and I notice when rendering that it's only using a bit less than 25% CPU.
tletter
As it already occasionally crashes, I think I'll leave it alone!!
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Not sure if unlocking all CPU cores would have an effect but have a look at the following -
https://www.techjunkie.com/enable-all-cores-windows/
https://www.youtube.com/watch?v=X8SrbRQpiXA
John a
sclg
They seem to be all enabled already. As I mentioned, Handbrake will happily register over 90% on the CPU meter!jparnold wrote: ↑Thu Nov 26, 2020 8:40 am Not sure if unlocking all CPU cores would have an effect but have a look at the following -
tletter
A red herring to be sure.jparnold wrote:Not sure if unlocking all CPU cores would have an effect
tletter
