Save As feature closes down PI program
ahk123
Post by ahk123 »
Lately if I create something and click on 'Save As" or 'Save', the program shuts down. I can save something if I use Image Optimizer or sometimes when I use the CTL+SHFT+S, it works sometimes.
What happens is that the window will show up to choose where you want to save but then it disappears and PI closes down.
I have uninstalled and reinstalled.....I have cleaned out registry and also under advice have uninstalled PEX 8.5 and reinstalled that and still this happens. every once in a while it works......
Don't know what to do. Ulead support just suggests uninstalling and reinstalling.
Very frustrating after working on item then losing it when trying to save.
I am taking the PIRC Beginners Workshop and don't want to lose anymore projects.
I would appreciate any help anyone can give.
Thank you very much Annette
htchien
operating_system: Mac
Post by htchien »
Windows version?
Display card driver version?
Latest updates and patches of PhotoImpact installed?
H.T.
Ted (H.T.)
ahk123
Post by ahk123 »
I have Windows XP professional Pentium 4
Display card 128MB DDR ATI Radeon 9800 SE
Version 6.14.10.6414
I have Photo Impact 10 with the new patch installed.
I have 1GB of RAM
htchien
Post by htchien »
I'm using Windows XP Pro SP2, too.
My PC:
Intel Mobility Pentium 3 1.13G
ATi Mobility Radeon
ATi Catalyst driver v6.14.10.6467
512MB DDR SDRAM
Ulead PhotoImpact 10 with the latest patch (v10.0.0.1)
Ulead PhotoExplorer 8.5 also installed.
But I do not have your SAVE FILE problem in my PI.
Maybe you can try to update your display card driver from http://www.ati.com ?
I wish I can help, but sometimes it's difficult if I cannot check your PC.
H.T.
Ted (H.T.)
ahk123
Post by ahk123 »
I went to the ATI site but the updates mentioned were mostly for game playiing and I don't want to start downloading stuff that may cause me trouble.
This morning the save feature is working........I guess it is tempermental.
Thank you for your help.
nounours
Save As shutdown PI
Post by nounours »
I have exactely the same problem as you described, I hve done everything uninstall clean register reinstall, but that will not works!
I'm very frustrated and dont know what to do anymore! :x
Please help!
htchien
Post by htchien »
Any other program installed in your system?
Ted (H.T.)
greenboy
Post by greenboy »
No problems here. I'm hammering the program fairly hard and use SAVE AS the majority of the time I'm saving. I'm running under XP Pro SP2 though I think I'd have the same results under XP Home. Sorry I don't have anything of more consequence to add to help you.
ahk123
Post by ahk123 »
I am the person who originally posted this thread and now no longer have the problem.
I really don't know what happened but I started just using the feature that is under the heading 'WEB' and scrolled down to "Item Optimizer" and saved it that way. After a while I tested the other way and it started working. So I have just chalked it up to a bug in the the new version of the program.
Hope this helps.....also I found if I used the "CTL + ALT + S key that the window for Save As would be activated.
greenboy
Post by greenboy »
I've been meaning to check if the bugs I found in PI XL still exist when going between Image Optimizer and File when saving PNG data. It would always toggle/change my FILTER option. Actually, Image Optimizer jpeg saving would also toggle my PNG filter option setting, I would notice the next time I went to SAVE AS PNG in the file menu.
The behavior of plain old Save would also be inconsistent - sometimes saving a filtered PNG, sometimes saving a much larger unfiltered one. That was annoying.
nounours
Partial solution
Post by nounours »
ahk123 wrote:I am the person who originally posted this thread and now no longer have the problem.
Hey thanks,
The image optimizer its partially solving the problem as long as I want save as JPG,GIF or PNG for other formats the problem is still there as the "CTL + ALT + S" key is also shutting down PI.
I have installed the soft in another PC and it works very well, I guess in my PC there is some incompatibility with some DLL but which one and how to find it? I can not reasonably remove all my installed software?
Is there any way to trace what is happening?
Thans to all for your help & suggestions
greenboy
Post by greenboy »
This is one that might require detailed technical support from Ulead, which they seem to do on a one-by-one basis, and not here, evidently...
But like so many other WINDOWS-oriented problems, perhaps an uninstall followed by a re-install might shake it loose. So that might be worth trying first.
Microsoft, tsk, tsk.
nounours
Finally solved but....
Post by nounours »
greenboy wrote:This is one that might require detailed technical support from Ulead, which they seem to do on a one-by-one basis, and not here, evidently...
Well I finally solved my problem by......reinstalling Windows! :x Thanks Bill!
Well now at least PI it works fine, I guess something in the registers or in a dll was incopatible!
So long.
