Text Cutter
chmartin1
Text Cutter
Post by chmartin1 »
Hi, I am running into an issue with the PaintShop Pro text cutter that I think could be a bug. I am opening up an image, adding text, using the text cutter, then applying a chisel and shadow effect to the text. The problem is it automatically cuts the text too close and when it does it cuts off some of the chisel effect and some of the drop shadow... Does anyone know a way around this? Thanks!
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Text Cutter
Post by Jean-Luc »
Could you put here a screen capture ?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Text Cutter
Post by LeviFiction »
Shape cutter uses the outline and fill of the text only, not the layer. So if the chisel and drip shadow extend beyond the stroke and fill of the vector text it won't be included in the cutout.
If you want to include the shadow and chisel you need to use a more manual option to select the area if the layer and then hide the text layer, use that selection to copy the image merged and paste as new image.
chmartin1
Re: Text Cutter
Post by chmartin1 »
Thanks for the help Levi - I was able to figure it out with your advice. Thanks!
