intel quick sync video
dawad
processor: i7 10750h
ram: 16gb
Video Card: gtx 1660ti
Hard_Drive_Capacity: 1tb ssd
Corel programs: videostudio 2019 2020
Post by dawad »
how do i know if this feature is working?
did a test of 1m 30s clip 1080 which took 25 seconds to render
made no difference intel quick sync or nvidia cuda or even with hardware acceleration switched off! all took same 25 seconds!
also did format factory utility test which said intel qsv not supported!?
intel site says my cpu does support quick sync!?
david
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: intel quick sync video
Post by asik1 »
How about a test with different shots?
Panasonic X900m, VXF1
dawad
ram: 16gb
Post by dawad »
Intel® Media SDK
i think i need to install this first for intel quick sync to work? can anyone confirm?
https://software.intel.com/content/www/ ... a-sdk.html
david
I would think rendering a 1 min 30 second video in 25 seconds is pretty good, what are you expecting to see.
To give the render a little more work to do add transitions, Colour correction etc.
From share deselect Smart Render, that will force to render everything.
That should give the render a bit more work to do, you can then view Task Manager – Performance
If you view the graph you should see peaks and troughs as the process passes the transitions where extra work is required.
Now you may find the CPU and GPU play their part.
I cannot comment on acceleration settings as I use AMD and so far Video Studio does not support AMD
dawad
ram: 16gb
Post by dawad »
seems that mvidia gpu disables quick sync
https://www.nvidia.com/en-us/geforce/fo ... is-forced/
maybe i should uninstall my nvidia studio driver that i downloaded since videostudio doesnt use gpu anyway?
david
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
I think things have changed since that post was made 7 years ago, I don't have any problem using nvidia or quick sync
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
You will note that in the performance tab options, there's a one-or-the-other choice between Intel quicksync and nvidia.
Intel claims that every cpu it has sold since 2011 has had a video cpu on board - all the software has to do is use it. Presumably, that's what intel quicksync is/does.
OTOH, nvidia support (a driver) for a graphics card may well turn off the intel quicksync as a clash of video processing
Which still leaves a choice of one or the other. Not both.
Vdanny
Video Card: Nvidia 1060 6GB
Post by Vdanny »
It is possible to use the Nvidia card and the Intel simultaneously but you usually have to enable this in BIOS. This will be an option for multiple-monitor mode and "iGPU". You may have to connect the motherboard display adapter to a second monitor to get this to work. On my system, I always use the Nvidia card for the more intensive graphics programs but this allows me to utilize Intel Quicksync for fast, high quality renders.
dawad
ram: 16gb
Post by dawad »
if i do manage to activate multiple monitor mode, where will the option be to switch between the two?
update: when i switch to hybrid mode in my lenovo settings it switches from nvidia card to intel uhd graphics
will this achieve the same goal?
david
chrishargrave
motherboard: Gigabyte AMD Ryzen x570 Aurus Elite
processor: Ryzen 7 3700x
ram: 32GB
Video Card: Radeon RX 5x 5600 xt 14GBPS 6gb Red Devil
sound_card: Amd HD Audio Device + realtec HD Audio
Monitor/Display Make & Model: iiyama generic PnP
Corel programs: VS Ultimate 2021, PSPro 2021
Post by chrishargrave »
From Trevor’s post do I take it that neither makes any difference if using AMD?
Regards Chris
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
Davidk wrote:Intel claims that every cpu it has sold since 2011 has had a video cpu on board - all the software has to do is use it.
This is not the case as for example, Intel’s line of “F” processors, e.g. Core i9-9900KF, do not have Intel Processors Graphics onboard so you will need a graphics card to run them.
tletter
