Is there a way to save in preferences shadow and animation
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
Hello,
Regarding TEXT.
I have noticed that whenever I restart VS10 the color I previously selected for border/shadow TEXT has not changed but the thickness has changed back to 0 requiring me to reset it.
Also the attribute (I normally use animation/fade/user defined/cross fade) has disappeared requiring me to set it up again.
Is there anyway I can somehow set these things so that the default to the way I used them editing the same project in the past?
Another annoyance is that I set the volume level for ALL clips at 20% (select the first clip using shift left mouse button and then the last clip) then select adjust volume then 20) but if I SPLIT audio the volume of the audio in 'clip' placed into the voice track has volume set at 100%. Is there something I can do so that the volume remains the same as in the original clip?
John
John a
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: Is there a way to save in preferences shadow and animation
Post by asik1 »
Why don't you save your text style as favorite and drag it to TL when needed?
Panasonic X900m, VXF1
jparnold
ram: 16GB DDR3
Post by jparnold »
"Good thinking 99" as Maxwell Smart would say.
Actually I never thought is was possible However when I tried it I did it by selecting the text in the timeline (right mouse click) and then selected 'Add to my favourites' and that added it but when I select it from 'My favourites' and drag it onto the timeline it also contains the text which I would then need to change.
That is no big deal BUT is that the way you do it and with that result?
John a
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Indeed, I shoot few symposiums a year, I add names and so on,
So once I make the style I drag it, click it and copy/paste the titles from the text program.
