VideoStudio 2020 can't open H.265/HEVC video from AMD's ReLive (only shows audio)..?
TroyTheTech
motherboard: Gigabyte Z370P-D3
processor: Intel i5-9400F
Video Card: AMD RX 5600 XT
sound_card: Realtek 8-Channel Onboard
Corel programs: PaintShopPro, VideoStudioPro
Post by TroyTheTech »
Just wondering if I'm missing something, as trying to import HEVC video clip into VS2020 (just upgraded! heh) it only sees the audio and imports it as an audio-only .mp4 file...
*NOTE: VS2020 opens H.264/AVC created with ReLive just fine
I looked in the Support area and saw that it needs Microsoft's HEVC purchased through the MS Store; so I purchased it for a buck, then restarted the PC just to make sure it 'took' and - same thing - VS2020 cannot open the video of HEVC files, it seems like? Here is what the MS Store page for it looks like now:
So it seems to be 'registered' with Windows 10...
Please let me know if there's anything else I can try. Thanks!
Edit:
Doing some more Troubleshooting, it appears that it cannot open the Video stream of a clip recorded with AMD's ReLive utility (the built-in game recorder in their GPU) - but it CAN OPEN HEVC in videos created with say, third-party video editing/compression programs, like Handbrake (it opened that one, video and audio streams, just fine).
I will change the Title to reflect this.
Not sure why VS2020 can't open these recordings created with AMD's ReLive (From GPU HEVC), since other editors can - for example, PowerDirector and Vegas both open ReLive recorded HEVC files - here is an example below of Vegas opening HEVC video created with AMD's ReLive:
It even recognizes it as "HEVC"...
Anyway, still open to any additional ideas on what I can possibly try still, to open ReLive HEVC files in VS2020
(but VS2020 does open HEVC files, just not ones created from this one app, directly after recording, at this time it seems)
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: VideoStudio 2020 can't open H.265/HEVC video from AMD's ReLive (only shows audio)..?
Post by michaeltee »
I've run into occasional problems with HEVC, not necessarily in VS but in general. You could try converting the clip to H.264 with a similar profile as a workaround. I believe HandBreak can do that.
Buceador
processor: Intel i7 X980
ram: 24GB
Video Card: Radeon RX580
Corel programs: Paintshop Pro 2020 Video studio 2020 tri
Post by Buceador »
I have just downloaded VS2020 trial in order to test compatibility with editing the ReLive videos. I have read the comments and realise that in order to do so I will need to convert them first using Handbrake or something similar.
Clearly adding this extra step is time wasting bridge too far and so I will have to uninstall the problem and continue with Powerdirector 17, what a shame that Corel cannot implement what must be a simple fix...
I have AMD onboard graphics and have seen the ReLive option in the past but for the life of me cannot locate, maybe an update has removed that or I'm just missing something.
I was going to record my own HEVC to test this.
Are you able to provide a sample recorded using ReLive, You would have to upload to a sharing site as an attachment here would be to large.
TroyTheTech
michaeltee wrote: Tue Nov 17, 2020 7:30 am I've run into occasional problems with HEVC, not necessarily in VS but in general. You could try converting the clip to H.264 with a similar profile as a workaround. I believe HandBreak can do that.
Thanks, you're right; if I really wanted to use VS for a Project I guess I'll have to do that at this time.
AMD's ReLive (GPU recording utility) can also do AVC/h.264 - which opens in VS2020 just fine - so perhaps I'll just use that, as well. [If I didn't, I'll put this in the first post]
Thanks though!
lata wrote: Tue Nov 17, 2020 11:50 am Hi
Nice idea, sure - I've deleted my little test from before so I'll make a little quick one and Upload it to Google Drive.
Here is the Link:
https://drive.google.com/file/d/10yEqTU ... sp=sharing
(Click DOWNLOAD in the upper-right corner to save the file itself to your system)
[It might get Deleted, but should be up long enough for everyone here to test if they want, heh]
It's just a short clip showing my desktop and this website, no audio was playing, sorry - but this is more of a test of being able to open the HEVC video stream in VS2020 anyway (See if it opens with no Video...and is seen as only an audio file...)
Here is some basic Info for the file:
Code: Select all
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main@L4.1@Main
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 5 s 667 ms
Bit rate                                 : 11.9 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Minimum frame rate                       : 30.000 FPS
Maximum frame rate                       : 60.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Stream size                              : 8.01 MB
Color range                              : Limited
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Duration                                 : 5 s 632 ms
Bit rate mode                            : Variable
Bit rate                                 : 2 274 b/s
Maximum bit rate                         : 320 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 kHz
Compression mode                         : Lossy
Stream size                              : 1.56 KB
Anyway, see if it opens with Video (anyone) - if it does, then that suggests something is up with just my system, heh.
I still have VS2019 installed, maybe something is conflicting? (Just thinking out loud..)
VS2020 has no problem with AVC/h264 though - and can open HEVC if I pass it through something like Handbrake - it was just something that was 'too bad' that it didn't work at this time (being able to 'just record HEVC with ReLive and Import it into VS2020 (directly)').
Thanks for the assistance, all. Take care
That clip shows only as MP4 audio on my VS 2020. It even appears with the VS audio thumbnail semiquaver icon in the library window, and Properties say it is an audio file with no video components. Yet MediaInfo gives the sort of information you included above. In other words, the same info you included in your first post.
FWIW it inserts and plays correctly in (Corel's) Pinnacle Studio 24.
TroyTheTech
Ken Berry wrote: Tue Nov 17, 2020 8:37 pm That clip shows only as MP4 audio on my VS 2020. It even appears with the VS audio thumbnail semiquaver icon in the library window, and Properties say it is an audio file with no video components. Yet MediaInfo gives the sort of information you included above. In other words, the same info you included in your first post.
Thanks a lot - that actually shows me it's not 'just me' anyway, heh
Yes, I'm glad I can open it in other video editors - I just was in the mood to use VS is all :mrgreen:
Your details from Media Info show the video as using a variable frame rate, now Video Studio does seem to struggle using this and could be the reason for the problems.
Are you able to change the settings using Re-Live to use a Constant Frame rate, that would be the best option, if not then using a Video Converter may be your only choice.
I’ll download the sample but will be later in the day when I can test, I don’t think I will see anything you and Ken have not seen.
TroyTheTech
lata wrote: Wed Nov 18, 2020 11:18 am Hi
Thank you for your investigative interest - it does not seem like the frame rate type can be changed... There is a frame rate frequency (30 fps or 60 fps) but that is about as deep as it gets (other than choosing AVC or HEVC).
VS2020 seems to have no problem with AVC video created with ReLive (AMD GPU rec.) - and that is still VFR. Kind of interesting, but I do know what you speak of however, many editors had issues in the past with VFR, good memory, heh.
So, it seems to be something specific to HEVC only, and VS2020. Interesting little issue.
Thanks again for your input.
