Working on coloring a map-board image with the paintbrush tool, I have noticed increasingly that it is impossible to save my work using the "Save" option, to the same file the image was originally opened from.
If I do this then whatever coloring I have done simply disappears (reverting to the original image area as it was when first opened), though at times the file on my drive will be updated. This latter aspect can be seen if I close out the image and re-open it.
Coloring will also disappear at times If I make a menu selection prior to saving my work.
I can however, save my work each time to a new file if I use the "Save As" option.
I have tested this issue on several file formats and it always occurs.
Does anyone have any idea what is going on here?
Thank you...
PaintShop Pro 2019 Glitch with "Save"
snaidamast
- ram: 16gb
- Hard_Drive_Capacity: 1 terabyte
- Monitor/Display Make & Model: LG 32inch
- Corel programs: PaintShop Pro
