Is there a Bounce in and Bounce Out effect in VS?
HenryBuck
Post by HenryBuck »
Hello again everyone,
I see that there is an Ease In and Ease Out for motion but is there a Bounce In , Bounce Out effect for motion? If so, I don't see it.
Thanks in advance..
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Re: Is there a Bounce in and Bounce Out effect in VS?
Post by gewb »
What version of VS?
HenryBuck
Post by HenryBuck »
Oh sorry VS 2019 Ultimate
gewb
Post by gewb »
So far no luck. Closest I found is the transition called Run and Stop. Smear is also interesting.
If you want a verticle bounce (up-down) that stablizes to steady, you could create it yourself using Customize Motion.
gewb
Post by gewb »
Just created a verticle bounce in Customize Motion - took about 5 minutes to tweak it the way I wanted. Now I can Copy/Paste attributes to reuse as desired.
HenryBuck
Post by HenryBuck »
Thank you gewb. I was hoping there was a slider :)
OK Thanks again!
gewb
Post by gewb »
Ureka!
There is a stock transition called Side which slides the next image (resource) from left to right as default but under Transition you can select L to R, R to L, U to D, D to U.
Who knew?
HenryBuck
Post by HenryBuck »
OMG I will have to check out and let you know. Thank you!
HenryBuck
Post by HenryBuck »
I'm playing it with trying to get the bounce effect.
Hi Henry
I am unsure what you are trying to achieve
a transition where one clip is replaced by another using a bounce movement, here you would use the A/B transitions.
Or
Simply animating an object in a bounce motion, customise motion would probibaly do that.
Once created can be saved as a path, view the library Paths for some ideas.
HenryBuck
Post by HenryBuck »
Hello Trevor,
It's actually an effect that was available in Flash and also with JQuery called "Bounce In" and Bounce Out" where the controls would usually be juxtaposed, bundled with "Ease In" and "Ease Out". They come handy using motion, especially with text.
Here's a variation of the effect:
https://codemyui.com/text-animation-bounce-effect/
Hank
