How to use alpha channel transitions with mattes?
ldor
motherboard: Lenovo 20NE001TRX
processor: AMD Ryzen 5 3500U
Video Card: AMD Radeon Vega 8
Hard_Drive_Capacity: 128GB+1TB
Monitor/Display Make & Model: Lenovo
Corel programs: VS 2020, VS X10, PSP X9
Post by ldor »
I purchased some transition effects. They include two mov files, the transition itself with alpha channel and a matte. The screenshots are attached below. Can somebody advice how to use them. I tried quite a lot but could not figure out.
matte file
matte file
transition file with alpha channel
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: How to use alpha channel transitions with mattes?
Post by asik1 »
Have you installed QT?
Panasonic X900m, VXF1
ldor
Post by ldor »
No I haven't. Does VS use QT somehow or do you mean that the transition should be created outside VS, using QT, and then imported? I would prefer doing everything inside VS, without a need for any other software.
I thought this matte could be used with the help of some blending modes. But whatever I tried, I could not achieve the exact effect where the moving rose petals would sweep the boundary between the two clips.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
How do you want to fully use mov file without QT?
I can't guaranty it will work but it's a starting point.
* You can always try to key the black instead using the alpha.
ldor
Post by ldor »
I just add the mov files to the timeline and VS accepts them
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
Just a note . .
the comments about QT refer to the codecs, not the player itself: the player has a security issue, but the codecs don't. There is a tutorial on how to install just the QT codecs on the Corel tutorials site, and it includes a demo of the effect when the QT codecs are absent.
