PaintShop Pro 2021 Update 1
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
Zantara
processor: i5-2100 3 10 Ghz
ram: 12Gb DDR4
Video Card: Intel UHD graphics 620
Hard_Drive_Capacity: 256SSD 1TB
Corel programs: From PSPX2 to PSP2022
Re: PaintShop Pro 2021 Update 1
Post by Zantara »
I don't know if it is my PC, but one of my main complaints is that PSP 2021 disappears when trying to switch from Complete to Photography workspace. You have to shut PSP down through Taskmanager and then it will open in Photography. This has been widely discussed in other topics about PSP 2021. On my computer it hasn't been addressed.
I am going to try the rest of the "improvements" over the weekend. I did see some new effects in ready-made AI effects in the Photography workspace.
I have exactly the same problem with the updated PSP 23.1.0.27. Changing the Workspace from Complete to Photography crashes the program, though curiously going from Complete to Sea-to-Sky does not. And like you, PSP hangs in the background and has to be killed by Task Manager so the program can be reopened; and then it opens in Photography. The only way round this is, in Complete, to open the Home Page and select Get Started. That presents, in the top centre of screen, a choice of the various workspaces. You select Photography, and there will be a momentary change in the screen, then you click on Edit, and it opens in Photography.
Going back from Photography to Complete seems to work, though...
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Those AI effects are available in every mode that can run the Instant Effects Palette, so Photography, Edit, and Adjust.
Is that an explanation why going from Complete to Sea-to-Sky doesn't have problems?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
There are different ways to select a workspace:
1) Click on the Home icon on top and select the desired workspace
2) Go to File/Workspace
3) In Complete workspace, customize the top menu and add menus to access the different workspaces (View/Customize/Commands tab/File):
2021 workspaces menus.jpg (9.98 KiB) Viewed 3667 times
4) In Complete, Photography and Sea2Sky workspaces, right-click on an empty area of the workspace.
On my system, only the #1 choice (Home button) is safe: no crashes.
The other choices produce often a crash when switching from Complete to Photography.
Zantara
ram: 12Gb DDR4
Post by Zantara »
@Jean-Luc...I tried that. You suggested this in another post. Still seems like solid advice. Unfortunately...after update 1 still doesn't work.
Also...if I switch from workspace Photography to Complete, I have lost my personal workspace settings. I have to load the file each time.
My brain is mush...I read somewhere that you can switch between workspaces by going to the Home screen. That does work.
Jean-Luc
Post by Jean-Luc »
Zantara wrote: Sat Oct 31, 2020 1:49 pm I read somewhere that you can switch between workspaces by going to the Home screen. That does work.
Yes, it is what I said:
On my system, only the #1 choice (Home button) is safe: no crashes. :)
Zantara
ram: 12Gb DDR4
Post by Zantara »
Just tried it...crashed. Wouldn't load Photogaphy workspace from Home screen. Tried to load Sea-to-Sky...loaded, but crashed as soon as I tried to try an effect :-(
Jean-Luc
Post by Jean-Luc »
Zantara wrote: Sat Oct 31, 2020 5:12 pm Just tried it...crashed. Wouldn't load Photogaphy workspace from Home screen. Tried to load Sea-to-Sky...loaded, but crashed as soon as I tried to try an effect :-(
Does it make a difference if an image is open or not on the workspace?
Zantara
ram: 12Gb DDR4
Post by Zantara »
Hi Jean-Luc
Thanks for responding.
Just tried that.
* Opened photo in Complete
* Went to Home
* Clicked on Photography
Nothing happened.
Until I clicked on the filename of the photo in the list.
Then it opened in Photography
* Clicked again on Home
* Clicked Complete
Nothing happened. Until I clicked the filename again. Then it opened in Complete.
That's a good workaround, but shouldn't be necessary.
And my personal toolbar and settings still won't load automatically. Have to refer to it.
Thanks a bunch!
Jean-Luc
Post by Jean-Luc »
Hi Zantara,
My default workspace is Complete and in Preferences I have selected "Keep last view".
From Complete, I go to the Home/Welcome screen. I move the tab/slider down (see screen capture) in face of Fall Into Savings.
I click on the Edit Tab on top. This will open the Complete workspace.
I close PSP.
I open PSP. It will open in the Complete workspace.
No need to load an image. I right-click on the empty workspace and select Photography.
PSP crashes.
I kill the process in the Task Manager.
I open PSP and in the Welcome screen, I move the tab/slider up (to Get started).
I select Complete, select a file, and click on Edit. The Complete workspace opens.
I close PSP.
I load it again and in the Complete workspace, I right-click and select the Photography workspace. Now, PSP should not crash.
It seems that the position of the tab (up or down) in the Welcome screen may cause the problem (UP is safer). I don't know why.
jimkirk363
motherboard: ASUS ROG CROSSHAIR VII HERO WIFI
processor: AMD Ryzen R9 3900XT at 4400 Mhz all Cores
ram: 32GB
Video Card: Inno3D NVIDIA GeForce GTX 1080 X2 8GB
sound_card: ROG SupremeFX 8-Channel High Definition Audio
Hard_Drive_Capacity: 41497 GB
Monitor/Display Make & Model: 1x U32J59XUQ (Main) 1x Samsung U28E590 (Secondary)
Corel programs: PSP ULT 2022, 2021, 2020,Aftershot3 Pro.
Post by jimkirk363 »
Since Update 1 load time even when splash screen is disabled can take upto 10 seconds.
Radim
ram: 4GB
Post by Radim »
jimkirk363 wrote: Tue Nov 03, 2020 12:35 pm Since Update 1 load time even when splash screen is disabled can take upto 10 seconds.
And it is faster or slower?
jimkirk363
ram: 32GB
Radim wrote: Tue Nov 03, 2020 3:22 pm
Slower by a lot.
