Work 2 photos concurrently
Peem
- motherboard: Belarc does not use term motherboardTOSHIBA Satell
- processor: 2-40
- Video Card: Intel R HD Graphics 4600
- sound_card: NVIDIA GeForce GT 740M
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.6"vis, December 2011
- Corel programs: VS 2021 Ultimate, Paintshop pro
I am having difficulty loading two photos into Paintshop Pro X6 so I can work on them at the same time. I want to be able to adjust earlier and later photos of the same location so that they correspond exactly and I thought I might be able to load the second one into another layer so I could switch back and forward between the layers and crop et cetera so that both correspond. Any suggestions would be appreciated. Peter.
Re: Work 2 photos concurrently
You should be able to Edit->Copy the 2nd image, Switch to the 1st image and then Edit -> Paste As New Layer (or simply drag with the mouse the 2nd image from its layers palette into the window of the 1st image),
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
Peem
- processor: 2-40
Thanks migf1,
I had posted an update that I seem to be achieving close to what I want by loading the two pictures and alternating between them rather than trying to put the one in a second layer but It does not seem to have appeared yet. Will try what you suggest. Peter
theavy
- motherboard: Dell 0CNDTP A00
- processor: Intel Core i7-9750H
- Video Card: NVIDIA GeForce RTX 2060 6GB
- sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
- Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
I'd suggest unchecking Tabbed Documents in the Window menu. That will permit you to open a number of images in your workspace, permitting you to arrange them as you see fit.
Peem
- processor: 2-40
Thanks All,
Will try your suggestions. I think I was over-complicating by trying to use layers and have had success just loading 2 photos at once. Use program infrequently so have to relearn.
