Upside-down text ??
garybeck
Upside-down text ??
Post by garybeck »
Anyone have an idea how i can fix this? I have the text attatched to the object path. it is facing the text inward no matter what, which means it's upside down on the bottom. is there any way to make it right side up on the bottom?????? thanks!!
(i'm using PSP9)
Zacabeb
motherboard: ASUS B450-F
processor: AMD Ryzen 5 3600
ram: 16 GiB
Video Card: nVidia GeForce RTX 2060
sound_card: RealTek Integrated Audio
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: Philips 236V4
Corel programs: PaintShop Pro X6, PaintShop Pro 2021
Re: Upside-down text ??
Post by Zacabeb »
First create a dedicated circle to which you can attach the text. Select that circle in the layers palette, and then select the Pen tool. Right click on the circle's edge and select Convert to path, then right click on it again and select Reverse path. Now you can attach text to the path and make it center on the inside of it. Finally, go into the properties of the path to which you attached the text, and uncheck the Visible box.
You might need to create a new text object to make it attach to the path.
garybeck
Post by garybeck »
wow. thank you sooooooo much. this has been bugging me for a long time. i was searching for that reverse setting and could not find it!!! thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
migf1
operating_system: Windows 8.1
Post by migf1 »
Actually you shouldn't need to create a new circle. You can convert to path and reverse the shape your text is already attached to. However a new path is the norm in order to add new text running in the opposite direction compared to the existed one (I think it is even possible to break the existed path to multiple contours with different directions, but I'm not 100% sure, plus it is a bit complex). In any case, here's another HEC video covering this topic: https://youtu.be/LcFzS2P9p-U (you may want to use the timestamps in the description, to skip parts you are not interested in).
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
