VideoStudio Movie Wizard
jcmmarin
Post by jcmmarin »
I use VideoStudio Wizard to create a short diaporama from images taken with a CANON Power G6. It seems to work but the image duration is 9seconds and the duration of a transition is 1.5 second. It seem that the default that I have set in my preferences 8seconds for an image and 2 seconds for a transition is not taken in account. I am using PAL output system.Can you help me? Thanks for your answers.
Jean-Claude
bryave
duration
Post by bryave »
You're computer might not be able to process with that exact duration since it is not yet rendered and needs to process every effects in your clip. ^_^
†bryave
jcmmarin
Post by jcmmarin »
The duration of an image and of a transition is the duration seen at level of the project in the edit phase. I was thinking that the default duration set in the preference panel will be used also in VideoStudio Movie Wizard.
jcmmarin
Post by jcmmarin »
