Videostudio pro 2020 is not asking about matching properties
rkstudio
motherboard: There is no motherboard listed
processor: Intel Core i7-855ou CPU 1.80 GHZ
Video Card: Radeon 540 Graphics
Hard_Drive_Capacity: 256 SSD
Monitor/Display Make & Model: Radeon 540 Graphics
Corel programs: Videostudio 2020 Pro
Post by rkstudio »
VS Pro is not asking me, if I want to match the Project Properties to those of the video, even though in the preferences. I have it clicked that I want to be notified about it. So now how would I do that manually since that isn't working in VS.
rkstudio
Re: Videostudio pro 2020 is not asking about matching properties
Post by rkstudio »
Well I just found out that it does when you drag the clip to the timeline, however, even though I selected yes, it didn't make any difference anyway. It's still just as choppy. I can't even work on my video now. It's impossible.
This is your third post today about the same problem, yet you have started three separate threads on it. As I just said in another of your posts you need to give us a lot more information on the properties of the video you are using and what you want to produce, and tell us what editing you have done, filters applies etc.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
See my remarks here about enabling smart proxy for jerky video clips
https://forum.corel.com/viewtopic.php?f=1&t=67481
rkstudio
Post by rkstudio »
Hi David. Maybe it's just me but when I clicked your link, it just brought me to a different thread of mine but I didn't see any posts from you there.
Davidk
ram: 16Gb
Post by Davidk »
No, it's not just you. My reply to that topic seems to have gone missing - I'd hoped that had ended when the new version of the forum was published some weeks back. So I've added a brief summary of my prior effort to that topic about editing jerky video.
And this topic is related. If you have the 'show message' box in the general tab of preferences ticked, then no message means:
- the properties of your project match those of the clip being imported for the 1st time; or
- the import isn't the first time a clip has been imported to your project: you only get that message the first time it happens and the properties of the imported clip don't match those of your project.
rkstudio
Post by rkstudio »
Hi David. I get that now. It's weird that your post would not show up. Anyway I get what your saying. I do have the 'show message' box ticked, but I thought it meant that I would receive the message every time. Oh also, I realized that the clip has to be pulled to the timeline to see the message anyway. I don't use VS very often but now my art followers are asking me more and more to make tutorial videos, so now the pressure is on. lol. Thanks for the help!
One of the reasons it would not come up is precisely because of the variable framerate. As I should have said in the other thread, Video Studio is not comfortable with variable framerates. It prefers -- even insists on -- standard framerates like 29.97/30 fps. So when presented with a variable framerate video, it doesn't see a standard video and will not ask if you want to project properties to match.
Just to be even more precise, variable framerates are variable! Just because one of your clips is 29.882 fps doesn't mean all the others you took around that time will have that same framerate. Some are likely to be lower, and some a bit higher, some probablyeven more than the standard 29.97 fps. So that is why VS cannot use a variable rate as part of project properties since the other rates will all be different for the different clips.
TonyP
motherboard: Gigabtye X570 Elite
processor: AMD Ryzen 9 5950X 16core 32threads
ram: 32GB 3200
Video Card: Sapphire RX 6700XT 12GB
sound_card: Realtek
Hard_Drive_Capacity: 10TB
Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
Corel programs: VS2023, PSP2023, Aftershot 3
Post by TonyP »
.... if using variable frame rate footage, it needs to be converted to constant frame rate by using something like HANDBRAKE which is free, and usually works quite well in making variable frame rate footage into constant frame rate footage.
Then there is the computing hardware you have.....
Choi seong chul
motherboard: Asus Z390
processor: InteCore i9 9900KF
ram: 64GB DDR4
Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
sound_card: MAYA U5 External Sound Card
Monitor/Display Make & Model: LED Raantec 24"
Corel programs: CVS X4,- X10,2018-2022,2023
Post by Choi seong chul »
In my case, I don't ask questions when the properties specified in the default settings are the same.
If it is different from the specified attribute, ask. I think this is normal.
