VS2018 offered to change the project settings to match video's properties. However, based on the above image, what would be changed?
tletter
Matching Video's Properties?
Re: Matching Video's Properties?
Based on the above what did change when you hit Yes
I would suspect the data rate of 99999Kbps would not be used, I think X2018 has a 65kbps limit
Not sure about the audio LPMC that may also change?
I did have a 99999kbps sample somewhere on the pc, not sure where that is? so without that its difficult to be accurate, certainly cannot test.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Nothing obvious which is why I asked if someone knew.lata wrote:Based on the above what did change when you hit Yes
Don't know what the actual limit is, but both VS2018 and X10 will output near or at 99999kbps, given a suitable source clip, if "same as 1st video clip" is used or you allow it to match the video's properties (see image). The limit of 65000kbps applies if you try to set the video date rate manually.lata wrote:I would suspect the data rate of 99999Kbps would not be used, I think X2018 has a 65kbps limit
I assume that you're referring to audio LPCM, be that as it may, Windows reports that the audio properties are the same either way.lata wrote:Not sure about the audio LPMC that may also change?
Fortunately it doesn't cause any issues so perhaps it's just anomalous behaviour that can be ignored.
tletter
