PSP X2 won't start
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
PSP X2 won't start
Post by jparnold »
Occasionally I find that PSP X2 (yes I know it is an old version but it does everything I want) won't start by any means (eg double click on an image file, double click on PSP icon and also select PSP and Run as Administrator).
When this happens I find if I reboot my PC (shutdown/restart) it then works as expected.
Any ideas what causes this as it seems to be the only app which won't start.
John
John a
migf1
operating_system: Windows 8.1
Re: PSP X2 won't start
Post by migf1 »
It sounds like an issue PSP seems to suffer from, in all versions. When it doesn't start, check in Windows Task Manager if PSP is already present there. If it is, kill it (all its instances). It should then start normally, the next time you launch it.
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
Helen94
Post by Helen94 »
You may also try Process Lasso that gives more possibilities and features than Windows task manager. You may truly see if it's working and change the priority of PSP X2 to make it work properly. I use it for Modern Warfare since Windows keeps changing the priority after updates...
jparnold
ram: 16GB DDR3
Post by jparnold »
Next time it happens I will try both.
John a
rondo
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Post by rondo »
Use Windows 10 Compatibility Troubleshooter- sometimes emulating an older version of Windows helps.
jparnold
ram: 16GB DDR3
Post by jparnold »
Thanks. I will try to remember to use that.
Well it did happen again since I posted (would not start) and although the PSP icon was not displayed on the task bar (as I had closed it earlier) I found an entry in task manager. When I removed it I could then start PSP.
Is there a problem using PSP X2 with Windows 10 (that when the user exits it disappears from the screen and task bar but is still in memory as a task?
John a
jparnold wrote:Is there a problem using PSP X2 with Windows 10 (that when the user exits it disappears from the screen and task bar but is still in memory as a task?
It's not a problem associated only with X2, but with all versions. I get it pretty regularly have done for years. Quite a few others have as well. I have just gotten used to looking in Task Manager and ending whatever process is still running there when I close whatever version of PSP I am using and then can't reopen it. That has always worked.
jparnold
ram: 16GB DDR3
Post by jparnold »
Thanks Ken.
I wonder if Corel know about it and if so they are not bothered looking for the reason as I have never had any other program/app cause that to happen. I can't remember it happening with Windows 7.
Also I don't think I have ever had any version of VideoStudio has caused me this problem either - Windows 7 or 10.
John a
Corel is well aware of it. It has been reported in this forum for years -- not that Corel monitors the forum. But we have also reported it during beta testing of various versions. The problem is that it doesn't affect everyone and thus pinning it down is rather elusive. The workaround of going to Task Manager also gives them a good excuse even if it takes a little time...
As far as I am aware the problem was fixed with the latest version PSP 2021, at least 95% +
There are odd occasions when it occurred but that was pushing the boundaries whilst testing.
Of course that does not help you using X2, at least you know to use task manager to end task.
I do recall someone on the PSP forum creating a file on the desktop as a shortcut to force PSP to close, maybe dreaming….
jparnold
ram: 16GB DDR3
Post by jparnold »
Hello Trevor,
Thanks for that info and it is good that (it seems) the problem was fixed with PSP2021.
PSPX2 does everything I want so I will put up with the occasional inconvenience.
Hope the '2nd wave' doesn't cause you too much 'invonvenience'.
John
John a
rondo
ram: 16 GB
Post by rondo »
I've used all versions of PSP since PSP 10 to 2021 and never have had the problem with the program shutting down or re-opening properly. So for some strange reason this does not happen to all users.
jparnold
ram: 16GB DDR3
Post by jparnold »
Thanks for your reply and observation. I think that the problem is confined to Windows 10 (you are using W7) as I can't remember it happening when I was using Windows 7.
John a
