I have probably a very simple question, but can't find the answer here on the forum or Google (can be due to my search skills of course
When I have an AVI-file as a result of digitalizing the DV-tape this has the following specs:
PAL (25 fps)
Microsoft AVI-bestanden
24 bits, 720 x 576, 16:9, 25 fps
Onderste veld eerst
Dv-video-encoder -- type 2
PCM, 48,000 kHz; 16 Bit; Stereo
When I have to choose which settings should be applied for the Output-file I don't know what to use:
1) Using the same settings as project/first frame is not useful as I don't like to get an AVI-file (would like to stream the content via PLEX) so MP4 is preferred
2) As I have read on the forum it's not useful to set the output settings to 4K or something, as this want improve the quality
3) Tried some different Output formats, but don't know what's the best setting to use as the output settings doesn't match the input values.
For instance the MPEG-2 (720x576) gives a much smaller output (not for a full screen).
Filesize etc. is not important for me as I have enough space.
I sincerally hope someone can help me with this question as this should be the easiest part of the whole editing process
