Low resolution in MultiCam production
ericburgermusic
System_Drive: B
motherboard: Motherboard
processor: Intel Cor i3-4130T CPU 2.9 GHz
ram: 8 GB
Video Card: Something
sound_card: who knows
Hard_Drive_Capacity: 2TB
Corel programs: Corel Video Studio Ultimate 2020
Post by ericburgermusic »
I just recently purchased VideoStudio Ultimate 2020 so that I could mix and render multiple cameras. My question is this:
All of original video is 1920 X 1080, but the rendered video from the MultiCam is only 854 X 480, making the quality almost unusable for me.
I do not see anyway to adjust the output quality so that the MultiCam render is of the same quality as the original video, nor do I see any reference to it in the manual. I am hoping I didn't purchase the wrong product.
Thank you for your help.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Re: Low resolution in MultiCam production
Post by tletter »
ericburgermusic wrote:All of original video is 1920 X 1080, but the rendered video from the MultiCam is only 854 X 480
VS's 480p default output is normally 720x480. What did you specify for project properties and for properties of the rendered file?
tletter
Hi ericburgermusic
Yes the multi cam vsp for some reason uses lower settings
However the mcc vsp is as such just a container holding your hd clips, the project file being inserted to the library.
Set the timeline properties to match your HD video properties
We then drag the mcce.vsp to the timelines all HD clips are added to the timelines which is using the higher HD settings 1920 X 1080.
Save that project. Now you are working with a he project matching the original video
The process of inserting one vsp to the timeline, effectively adding one vsp inside another vsp is known as nesting.
It would be better if mcce did use the properties of the original video for camera one.
TonyP
motherboard: Gigabtye X570 Elite
processor: AMD Ryzen 9 5950X 16core 32threads
ram: 32GB 3200
Video Card: Sapphire RX 6700XT 12GB
sound_card: Realtek
Hard_Drive_Capacity: 10TB
Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
Corel programs: VS2023, PSP2023, Aftershot 3
Post by TonyP »
You can change the resolution of the proxies.
In the MCE, you will see the "gear" in the upper left corner.
Gear>Smart Proxie Manager>Settings, you can choose the resolution of the proxy files created.
Just make sure that your computer is capable of handling the files smoothly when creating your multicam. You can experiment, but your hardware my struggle.
As posted above, these are proxies and are used in final exporting. Proxies are made to make lower res files that are much easier on your computer hardware.
ericburgermusic
System_Drive: B
ram: 8 GB
I set the project at 1920 X 1080.
I just can't seem to make it look less than Crappy.
Can you give us some more details
1 / First insert your video file to the library, you can create a new library page for these files.
2 / Right click one of the clips, the one that is intended to be Camera 1 as that frame rate will be used, what are the properties?
Set up the timeline.....
3 / Drag the first clip / camera 1 clipto the timelines, should show a message to match the project properties to the video clips properties
4 / Also check Settings Project Properties to make sure they are as your video clips properties.
5 / delete the clip from the timeline
6 / from the library select all clips to be used in MCE, right click the selection for Multi Cam Editor, this opens the Source Manager with your clips selected
7 / Top – Project Name – you can give the project a new meaningful name
8 / Click ok will open the editor
9 / Set a couple of options, then OK to close
10 / returning to the timelines the new project shows in the library
11/ drag that .vsp to the timelines to display as expanded, DO NOT hold Shift to flatten
12 / File – Save as to save the project
Now you are working with a 1920 x 1080 project containing 1920 x 1080 video files.
13 / File – New Project to clear the timelines
From the library
13 / double click the MCE.vsp to open the project and continue editing in MCE
14 / repeat from #10
Does that improve things.
