I load a picture into PSP X2 and select a rectangle part of it.
Now I want to resize (=shrink) this selected area by 50%
So I click on menu
Image-->Resize
and adjust the settings as follows:
Width=50 percent
Height=50 percent
Advanced settings=YES
Lock Aspect Ratio=YES
Resize all Layer=NO !!!!!
When I click now on the OK button the whole picture is resized instead of only the selected area.
Why?
Do I have to convert the selection to extra layer?
How?
Thank you
Peter
How to resize only a selected rectangle?
Lies54
- motherboard: Lenovo
- processor: Intel Core i5 2400
- ram: 4GB
- sound_card: High Definition Audio-apparaat
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Acer
- Corel programs: x9, 2018, 2019, 2020, 2021
Re: How to resize only a selected rectangle?
Have you turned your background layer into a raster layer?
Hi Peter,pstein wrote: ...
How?...
Yes, you should promote it to a new layer 1st, either via the menu Selections->Promote Selection To Layer, or by hitting Ctrl+Shift+P on your keyboard or by right-clicking on the image layer in the layers-palette and selecting: Promote Selection To Layer PS. ... or by switching to the Pick tool and then clcking inside the selection (there are more ways too
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Hi Peter,
after you have converted the selection to a layer as explained by migf1, in the Resize settings window, uncheck Resize all layers. This will resize only the active layer.
pstein
- Corel programs: PSP X2
Ok, thank you.
Promoting the selection as additional layer has a disadvantage:
The selection is DUPLICATED.
In other words: after duplication and shrinking the original selected area is still alive.
So the promoting layer feature has no no benefit of the "traditional tedious workaround":
1. Cut the selection
2. Paste as new image
3. Shrink/resize
4. Copy new, shrinked picture into clipboard
5. Insert in the original picture
Is there no promote selection as new layer WITH deleting/cutting old area?
3. Shrink/resize
I am not sure what you are trying to do Peter.
To cut instead of duplicating the selected area, you can drag the selection with the selection mode set to Replace
https://gyazo.com/0ef3ff96576503647d5ba634394ba468
This of course leaves a hole behind the original area, and a floating layer in the layers-palette (which you have to decide what you want to do with it).
Btw, you can get the same results with Ctrl+X for cutting, and then Ctrl+E and clicking anywhere in the picture, for getting the selection as a floating layer (or just Ctrl+L, for getting the cut selection as new regular layer).
In all these cases, you will have a hole behind the original area. Later versions of PSP provide a Magic Fill feature. Depending on the picture and the selection, it can help in filling up that area (at least for not starting from scratch).
https://gyazo.com/a312981a9421d4a0e4ef3a252eaf8e0c
pstein
This is exactly what I need.migf1 wrote: To cut instead of duplicating the selected area, you can drag the selection with the selection mode set to Replace
Even better....After moving the selection I need no more "promote Layer" action
Thank you
You are welcome! I'm glad it worked for you.
