Photo Background change
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Photo Background change
Post by Jean-Luc »
okyou wrote: Do you know what did I do wrong to get this error ?
Does this happen each time you try it? It may be random.
Jean-Luc
Post by Jean-Luc »
okyou wrote: I want to cover the left brown spot in the layer. What I did is to copy part of the right area and cover up the brown spot.
From where is coming this brown spot? If you have filled the empty raster following my steps, the page should be uniform.
migf1
operating_system: Windows 8.1
Post by migf1 »
Jean-Luc wrote:
okyou wrote: Really thanks for your help. I tried to follow your steps but when I tried to drag the layer to the workspace. Nothing happened. Did I miss some steps ?
Most probably okyou is working in a Tabbed Documents interface, where drag & drop on the workspace is not working. When the Tabbed Documents is enabled (Windows menu) then the layer drag & drop for getting a new image works if we let off the mouse on the empty area of any open toolbar (in PSP 2021 just ignore the icon showing that we cannot).
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
Jean-Luc
Post by Jean-Luc »
migf1 wrote: Most probably okyou is working in a Tabbed Documents interface, where drag & drop on the workspace is not working.
Yes! Good catch! :D
Okyou should uncheck Tabbed documents.
okyou
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 2TB
Corel programs: X9 Ultimate
Post by okyou »
Oh Thanks. I turned off the Tabbed Document and it worked. However, if I only want to change only a region of the original layer with a bottom layer, then there will be a slight color mismatch line between the 2 layers as shown as attached pic. How can I smooth them out the color mismatch ?
Jean-Luc
Post by Jean-Luc »
Following my steps, I suppose you made a horizontal selection and not a vertical. You cannot use a horizontal selection because you have a shadow from left to right on your page. This will need to apply a Luminosity gradient to correct it and it is not easy to obtain a good result. I suggest you make a vertical selection as shown in my messages. The vertical selection has a better uniform luminosity.
okyou
Video Card: onboard
sound_card: onboard
Post by okyou »
Thanks for your tips.
