Sound Out of Synch in MF3
carysteiner
Post by carysteiner »
I need help ASAP!
Our video was edited in Media Studio 3. We stripped the audio, had it 'sweetened' and put it back in. I painstakingly matched the audio to the video. The avi files look and sound perfect.
When I burn to DVD, the audio is out of synch.
PLEASE help me with possible solutions... just identifying the problem isn't quite enough!!!
Thanks to all.
jedi-jae
Post by jedi-jae »
Before you burn the project, have you previewed the video, if so is the sound in synch? It may not be a burning problem, I found that using the Enhance Video panel knocked my sound out of synch if I used the volume control to lower the videos sound level.
carysteiner
Re: Sound out of synch in MF#
I've previewed the avi files and they're fine. The video and audio match in the preview, but not after burning.
keithm
Post by keithm »
Try this - it worked for me.
CONFIGURATION & SET-UP:
1) From Ulead Tech Support: check the settings in your DVDMF.ini file
a) Close DMF. Locate DVDMF.ini file in the C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD MovieFactory\2.0. (or 3.0 depending upon the DMF version you have)
b) Open it and add three flags in the VIODRIVER section as shown below.
[VIODRIVER]
CloseAudioDTR=1
AlwaysAudioSeek=1
AlwaysVideoSeek=1
carysteiner
Re: Sound Out of Synch in MF3
Thanks Keith!
I'll try it when I get home tonight...
carysteiner
Oh NO!
There is no dvdmf.ini file anywhere on my system!
What now?
ploggy
Post by ploggy »
make sure you can view the hidden files. Set it up in the Folder Options.
Who? Me?
DVDDoug
Moderator
Post by DVDDoug »
Search the forum for "sync", and you'll find lots of suggestions. This is a common problem which seems to have several different causes & soulutions. (You may also find some hints on the Video Studio and DVD Workshop forums... this problem shows-up on those products too.)
The avi files look and sound perfect... When I burn to DVD, the audio is out of synch.
I suspect a corrupt AVI file. Does the sync error seem to be constant, or does it get worse later in the video?
If you have a few corrupt video frames, these frames may be thrown-out during MPEG encoding, or during re-multiplexing. These lost frames will shorten the video stream without shortening the audio stream... Now they are out of sync.
Maukka
Post by Maukka »
I had similar problem when burning with MSP7. Your problem might be simiar.
My AVI and even MPEG files were perfectly in sync before burning to disk. But lip sync was lost during burning. It turned out that for some reason MSP had started to produce corrupt MPEG files. I reinstalled MSP7 entirely and that solved the issue.
Hope that helps
Maukka
