PSPX9 recorded script "Runs" OK but Batch does nothing
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Post by SJS »
I recorded a script to apply an effect, then to reduce the saturation. When I run this on an open file, single step, it works fine, silently or interactively.
But when I use the script in Batch Process my new files are created/saved without either action: no changes are applied.
Windows 10, PSP X9 19.1.0.29 x64
What do I need to change in my recorded script for Batch Processing?
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'19.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Default,
'Version': ((19,0,0),1)
# Colored Foil
App.Do( Environment, 'ColoredFoil', {
'Angle': 250,
'Blur': 12,
'Color': (70,43,20),
'Detail': 16,
# Color Adjust HSL
App.Do( Environment, 'ColorAdjustHSL', {
'HSL': {
'Colorize': False,
'Master': (0,-22,2),
'MasterColorize': (89,35,-30),
'Red': (0,0,0,315,345,15,45),
'Green': (0,0,0,75,105,135,165),
'Blue': (0,0,0,195,225,255,285),
'Cyan': (0,0,0,135,165,195,225),
'Magenta': (0,0,0,255,285,315,345),
'Yellow': (0,0,0,15,45,75,105)
cosmicDread
motherboard: MSI MPG Z390 Gaming PRO
processor: Intel Core i9-9900K
ram: 32 GB
Video Card: GeForce GTX 1080 Ti
Hard_Drive_Capacity: 6 TB
Monitor/Display Make & Model: Acer Predator X34
Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
Re: PSPX9 recorded script "Runs" OK but Batch does nothing
Post by cosmicDread »
I was able to get your script to work on the first run with a batch process. 8) I've never done batch process before. :?
Here are the steps I took:
(1) Selected File / Batch Process...
(2) Added three .jpg files using the Add button. The images were in the same folder.
(3) Clicked the Next button.
(4) Clicked the Script button on the right-side of the Batch Process window.
(5) Selected the script that you posted.
(6) Selected the Next button.
(7)
Under Destination Folder:, I have New selected.
Under Filename:, I have Original selected.
Under File format:, I selected PNG.
(8) Selected the Start button.
Maybe there is something going on that you don't understand. :?:
Best wishes,
Charles
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
