Problem with fresh install in Fedora 32
Bugs & Suggestions
tony_redink2000
operating_system: Linux
System_Drive: N/A
Post by tony_redink2000 »
I've just installed a fresh system of Fedora 32.
While trying to install AfterShotPro3 I get this error.
dnf install ./'AfterShotPro3.rpm'
Last metadata expiration check: 1:24:02 ago on Sun 02 Aug 2020 17:04:57.
Error:
Problem: conflicting requests
- nothing provides libgstreamer-0.10.so.0()(64bit) needed by AfterShotPro3-360380:3.6-0.380.x86_64
- nothing provides libgstapp-0.10.so.0()(64bit) needed by AfterShotPro3-360380:3.6-0.380.x86_64
I've seen a few postst that suggest using the repo from https://copr.fedorainfracloud.org/coprs ... eamer0.10/
However, there are even more dependancies that are not met.
dnf install gstreamer-plugins-good
Last metadata expiration check: 0:11:07 ago on Sun 02 Aug 2020 18:23:31.
Error:
- nothing provides gstreamer >= 0.10.36 needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides gstreamer-plugins-base needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstreamer-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstbase-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstinterfaces-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstaudio-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstnetbuffer-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstrtp-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstvideo-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstcontroller-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgsttag-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstfft-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstpbutils-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstriff-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstsdp-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
- nothing provides libgstrtsp-0.10.so.0()(64bit) needed by gstreamer-plugins-good-0.10.31-25.fc32.x86_64
(try to add '--skip-broken' to skip uninstallable packages)
kneeke
Re: Problem with fresh install in Fedora 32
Post by kneeke »
I've asked Corel support if (and when) they plan to update the dependencies, but so far no useful answer.
But, since Qt versions are binary compatible, you can try the following (seems to work for me op opensuse):
Make sure you have Qt 5.x installed (use the version from your distribution, for my situation it's Qt 5.12)
Then install AfterShot, ignoring the missing dependencies.
Goto the lib dir inside the installation directory (/opt/AfterShot3(64-bit)/lib)
Remove ALL libraries except libbibblesdk.so.5 and libOpenCL.so.1
Now you should be able to launch/use AfterShot without problems.
(Not everything is tested this way, so it might be that you run into problems..)
rstory
System_Drive: N/A
Hard_Drive_Capacity: 2TB
Post by rstory »
I had one more issue after following kneeke's suggestion - /opt/AfterShotPro(64-bit)/bin/qt.conf was setting pluging path to Aftershot's version. Also, I did not restore libOpenCL.so.1 and ocl-icd was providing a version in /usr/lib64/.
My steps:
* install AfterShot without dependency check
Code: Select all
rpm -ivh --nodeps AfterShotPro3_64bit-3.6-0.380.rpm
* install qt
Code: Select all
dnf install qt
* remove embeded libs in /opt/AfterShot3(64-bit)/lib (except libbibblesdk)
Code: Select all
cd /opt/AfterShot3(64-bit)/lib
mkdir oldlibs.xx
mv * oldlibs.xx/
mv oldlibs.xx/libbibblesdk.so.5 ./
* comment out plugin path in embedded /opt/AfterShot3(64-bit)/bin/qt.conf
Code: Select all
#[Paths]
#Plugins=/opt/AfterShot3(64-bit)/lib/plugins
* Now try and start. You *might* need compat-openssl10
Code: Select all
dnf install compat-openssl10
tony_redink2000
System_Drive: N/A
I followed the steps by rstory which got Afteshot back up and running.
I found I needed to edit the qt.conf commenting out the pugin dir file and couple of extra libraries. libqt5keychain.so.1 and libQt5WebKitWidgets.so.5
dnf provides libqt5keychain.so.1
sudo dnf install qtkeychain-qt5
sudo dnf reinstall qt
dnf provides libQt5WebKitWidgets.so.5
sudo dnf install qt5-qtwebkit
wdingus
System_Drive: N/A
processor: fast
ram: plenty
Hard_Drive_Capacity: terabytes
Monitor/Display Make & Model: nice
Corel programs: none
Post by wdingus »
Any luck in making this work with Fedora 32? Mixed results here... Thanks to Daniel for helping get it this far.. https://www.ctrl.blog/entry/how-to-afte ... edora.html
$ /usr/bin/AfterShot3X64
Install Path: /opt/AfterShot3(64-bit)
LD_PATH: /opt/AfterShot3(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS:
QSocketNotifier: Can only be used with threads started with QThread
libpng warning: iCCP: known incorrect sRGB profile
Qt WebEngine seems to be initialized from a plugin. Please set Qt::AA_ShareOpenGLContexts using QCoreApplication::setAttribute before constructing QGuiApplication.
QObject::connect: No such signal QAction::trigger(bool)
QObject::connect: (receiver name: 'Directory View')
^ just starting it up
QMutex: destroying locked mutex
^ after loading 3 Canon .CR2 files
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
^ after right-clicking and choosing to "Edit with AfterShot HDR" which does *not* work
marcinek
System_Drive: N/A
motherboard: Lenovo
processor: Intel i7
ram: 32GB
Video Card: Intel UHD620 + Nvidia GeForce MX250
Hard_Drive_Capacity: Rusiec
Monitor/Display Make & Model: Lenovo UHD IPS 27"
Corel programs: AfterShot Pro
Post by marcinek »
Hi!
Here is the workaround how to make AfterShot run in container on probably any modern Fedora or other distro.
I have installed AfterShoot in Fedora 31, last known to work with AS, inside container running on Fedora 33.
Dockerfile:
Code: Select all
FROM fedora:31
ADD AfterShotPro3.rpm /AfterShotPro3.rpm
ADD start.sh /start.sh
RUN dnf -y install AfterShotPro3.rpm glx-utils xterm mesa-dri-drivers compat-openssl10 xorg-x11-fonts-Type1 xorg-x11-fonts-ISO8859-1-100dpi dejavu-sans-fonts dejavu-serif-fonts liberation-serif-fonts
CMD ["/start.sh"]
AfterShot is started via
Code: Select all
start.sh
because something needs to initialize GLX. In this case glxinfo. So entry point script looks like this:
Code: Select all
#!/bin/bash
glxinfo
Build the image:
Build the image with command:
Code: Select all
$ buildah bud -t aftershoot:3
Run the container
Here is some magic. The container needs access to the hardware, network, .Xauth and your images folder:
Code: Select all
$ podman  run --net host --privileged --env "DISPLAY" --volume "$HOME/.Xauthority:/root/.Xauthority:rw" --volume "/etc/machine-id:/etc/machine-id"  --volume "/home/marcinek/Obrazy:/root/Pictures" localhost/aftershoot:3
Cleanup
Containers tends to stay in "Exited" state after main job finishes so they need to be manually deleted:
Code: Select all
$ podman ps -a
CONTAINER ID  IMAGE                   COMMAND    CREATED         STATUS                    PORTS   NAMES
f347e4a86118  localhost/aftershoot:3  /start.sh  44 seconds ago  Exited (0) 3 seconds ago          festive_banach
$ podman container rm f347e4a86118
f347e4a861185c3c663d0203ba1b2e6854692cae30303a2e4cb3c42bb70d8b30
Considerations
There is the way to make containers disappear after the exit.
Question for Corel: Which directory should I map for my container to save the license? Now it starts trial period every time the container is started.
Enjoy!
Voiceofexperience
motherboard: ASRock
processor: AMD FX-4300
ram: 32 gb
Video Card: AMD Radeon 7 200
Hard_Drive_Capacity: 5 tb
Monitor/Display Make & Model: LG S-IPS
Corel programs: None - I'm fussy.
Post by Voiceofexperience »
And that amount of additional fannying about, simply in order to make a commercial product work, is OK with you?
It's like buying a car, having to build the engine yourself, and being happy with the deal...
