I just spotted a couple more bugs
1. when SHIFT running a shortcut in order to modify the paths in the ini-file, if you Cancel out all dialogs, ssr crashes
2. if you specify a user ini-file, if its contents are not in the expected format, ssr overwrites the file, making it a valid ini-file with default values (thus you loose the original contents).
Not sure when I'll fix those, probably in this coming weekend or sometime next week.
Also, I've almost finished a more flexible GUI for the Create SSR Shortcuts tool: http://prntscr.com/tz1s5f
I'll probably put that, and the fixed ssr in a v0.2.3. or something.
