I bought Multi-Color Confetti Overlays on July 6th.
I am in trouble and who can help?
However, it cannot be downloaded and installed.
When you click Install, the following message appears.
“There is no app associated with this file to do this.
Install the app or make a connection from the main app settings page if it is already installed.”
This is a temporary file and cannot be used.
I understand this as sending a download link as a MOV file.
There is no download link. By the way
It appears to have been purchased from Get More and cannot be downloaded once installed. Message only
Appears. I contacted Corel, but I haven't solved it yet.
Please refer to the link below.
https://youtu.be/5taqXGj16eg
Download Multi-Color Confetti Overlays
Choi seong chul
- motherboard: Asus Z390
- processor: InteCore i9 9900KF
- ram: 64GB DDR4
- Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
- sound_card: MAYA U5 External Sound Card
- Monitor/Display Make & Model: LED Raantec 24"
- Corel programs: CVS X4,- X10,2018-2022,2023
Re: Download Multi-Color Confetti Overlays
Have you had any response from Corel Support?
When did you purchase this template (Multi-Color Confetti Overlays.exe). was this with 2020 or an earlier version?
The file in the %temp% folder has a mark after .exe, looks like .exeA, is this normal for you to see that mark?
You show the file in %temp%, I assume you doubled click the file to run
The file only shows as 1Kb which does seem a little small maybe indicating it is corrupt.
The instructions also say that once installed a folder will be placed on your desktop, have you looked on your desktop? I would assume having a similar name to Multi-Color
Choi seong chul
- ram: 64GB DDR4
Corel Support answered today.
He said he would contact the department and send you a download link.
But it is not sent yet.
Purchased on July 6, 2020.
It is marked as exeA. This is not a file. Click Install
Appears. This is a temporary file and cannot be used.
Nothing appears on the desktop.
In order to appear on the desktop, the download must proceed when you install Get More\
Install. I think this is a problem that appears because there are no links to download.
I see it by Corel's mistake. Link to download exe file is not linked.
I can't solve it quickly, and I asked for a refund, but there is no answer.
Did you see this post regarding Particle Illusion a free standalone version
A lot of effects unfortunately uses a solid background not transparent, renders the effects to MP4, then we could use VS chroma key to remove background
But if you are creating special effects this may be useful, just another option.
Of course you may already own the full version.
https://forum.corel.com/viewtopic.php?f ... 2a5c944fc9
Choi seong chul
- ram: 64GB DDR4
Yes thank you.
I am using the program I said.
If you can handle it well, you can create a particle effect
I think it is a good program.
Inexperienced in dealing with the program. I bought colored paper that I made.
But there was a problem. Thank you.
And the program mentioned above can also make a MOV transparent background.
Rended\ Channels \ RGB+Straight Alpha selects MOV
Is made.
Is made.
Choi seong chul
- ram: 64GB DDR4
Today Corel admitted the mistake and apologized. I received a download link.
Downloading and installing is normal.
This program cannot be downloaded from Video Studio.
There was a separate download link.
The problem is that there is no download link in the purchase receipt.
Thank you for the info to create a transparent backgroundChoi seong chul wrote: And the program mentioned above can also make a MOV transparent background.
Is made.
Choi seong chul
- ram: 64GB DDR4
And you can also import background images.
However, only PNG files are imported.
