Playing clips from ScoreFitter library
zehavi
- processor: Intel[R] Core[TM] i7-8700 CPU 3.20 GHz
- Hard_Drive_Capacity: 465 GB
- Monitor/Display Make & Model: LG
Unfortunately, in VS 2020 ultinate, I am not able to play a music clip directly from the ScoreFitter library. The program is freezed by trying it.
I can only play the clip after locating it in the music track. Enclosed is a illustration screen image.
Thank you for any help
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Playing clips from ScoreFitter library
What happens if you play the ScoreFitter tracks from the Auto Music icon
Choi seong chul
- motherboard: Asus Z390
- processor: InteCore i9 9900KF
- ram: 64GB DDR4
- Video Card: NVIDIA GeForce RTX 2080 Ti 11GB
- sound_card: MAYA U5 External Sound Card
- Monitor/Display Make & Model: LED Raantec 24"
- Corel programs: CVS X4,- X10,2018-2022,2023
That's right.
However, it does not stop. The time display progresses without silence.
You need to bring it to the Music track to hear it.
I tried using Score Fitter which worked ok
When I selected Score Fitter Music the program started to update/ prepare library, that’s normal for the first time use.
I selected the Classical Sinfo, then play started to create / render a temp file, I was then able to play the clip from the library
The rendered sound file is saved here:-
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\23.0\ScoreFitter
I would now close the program, then try deleting the content of that folder.
Launch the program again and try using Score Fitter
If the above does not improve things
Close VS, from the folder link rename the folder 23.0 to 23.0_old
Restarting VS will create a new 23.0 effectively resetting the program
zehavi
Unfortunately, The steps suggested by Trevor didn't help.
Besides The Score Fitter folder, in all the other music folders including the Auto Music, I have no problem to play any clip directly from the library.
If in the future I will want to use any clip from the Score Fitter I will move it to the music track in order to listen to it, in spite of the inconvenience.
Thanks you all
Thanks you all
I do not understand why the clips do not play from the library, I can only suggest re-installing the program?
Auto Music uses the same audio files as ScoreFitter Music
With Auto Music you do have a greater selection regarding the song and version choices.
You can then play your selection, set the exact duration and add to timeline, with Auto Trim will add to the entire length of the clip from the cursor position.
Robert mentioned using AutoMusic in his reply.
zehavi
Thank you Trevor,
It really looks that that it's better to use the Auto Music.
Meantime I preffer this option instead of re-installing the program.
Choi seong chul
- ram: 64GB DDR4
The odd thing is that the start and end points are attached to the trim markers at the start point.
And the time code time display is in progress.
There seems to be a problem.
- RobertOZ
The trim markers are ineffective when playing the music direct from the library. But all the tracks should and do play correctly. Only when the track is added to a music track can the yellow trim markers be moved
Hi Choi seong chul
There is NO problem
The ScoreFitter music samples are not true audio files in the sense that they are not Wav, MP3
If you right click the clip there is no options for Locate on Computer as they do not exist as an actual sound file.
They are audio system files use in Auto Music where they can be used at any set length on the timeline, and yes the program has made some of the Auto Music files available in the library.
When you first add one to the timelines and play it is rendered to a Wav file saved to the ScoreFitter folder here-
Now those are true audio file (Wav) but have a fixed maximum duration.
There is NO problem
Choi seong chul
- ram: 64GB DDR4
Yes, I think so. At VS2019
Sound is heard even in the same situation. There are no sounds heard only in 2020.
Music is also weak on the music track. Problems only in 2020.
Hi Choi seong chul
I am sorry you are having problems with TSM, I recall another user having problems in playing the TSM from the library
I have tried / tested both 2020 and 2019, I do not have a problem in playing the TSM, sound levels are the same using 2020 and 2019
As TSM is used in Auto Music we advised that option should be used especially as there are more sound options / variations available.
Do you have problems using the Auto Music feature
When you select one of the clips in TSM library do you see the render progress as my attached image If you view this folder, does it contain Wav files
C:\Users\UserName\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\23.0\ScoreFitter
Are you able to play those files using your media player?
Choi seong chul
- ram: 64GB DDR4
You can play normally in the path you mentioned.
The rendering progress is displayed.
However, there is no sound.
I can only suggest that you use the Auto Music option to view / play and select your sound files.
You do have greater scope in choosing the sounds variations using Auto Music- Category / Song and Versions
If you have not done so I would suggest you re-install the program to see if that fixes the library playback?
