Particels anyone?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Particels anyone?
If you fancy you can grab for free
Free standalone : https://borisfx.com/downloads/?&product ... Standalone
Free Emitter: https://borisfx.com/downloads/?&product ... 20Emitters
And basic start
https://www.youtube.com/watch?v=zRXvP8FM-rw
And basic start
Panasonic X900m, VXF1
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Particels anyone?
Particle Illusion was a Wondertouch product, I have had version 3 since Oct 2007, a very expensive program at the time, now Boris provide it free, can highly recommend this program
Thanks Adi
I'll give that a try
asik --- beat you by around 12 hours, but I deliberately posted in the Video and DVD Forum as the product did not relate directly to VS.
https://forum.corel.com/viewtopic.php?p=379633#p379633
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Unfortunately there is no Particle Illusion plug-in for VS. In any event, if you want a quick overview of what Particle Illusion does, see https://www.youtube.com/watch?v=ilUUHOkGc1o
tletter
tletter
- RobertOZ
But to purchase the plugin version will cost you US$295 assuming you have Adobe,Avid, Apple Final Cut Pro, Blackmagic, Vegas pro
Using as a standalone is no problem, just create and render, then import into VS
Vdanny
- Video Card: Nvidia 1060 6GB
Please be aware that the free standalone version does not allow the use of a background image or video. You can export the particles you create in ProRes 4444 but I don't believe that this is a format that Videostudio supports. If you can convert that to a series of image files with alpha channel, you could then import it into Videostudio and composite it using one of the blend modes.
- RobertOZ
Have uninstalled the Boris version, too many issues, none of the tabs work.
So will stay with my trusted Wondertouch version 3
Hi RobertRobertOZ wrote:Have uninstalled the Boris version, too many issues, none of the tabs work.
I dont have a problem with the program seems to work ok, all tabs respond.
Now how to use the program is another matter but it does appear to be responding to everything i try
- RobertOZ
Will try a reinstall later, problem is when hovering over a tab, the dialog box opens, but as soon as you move down to select a category, the dialog box disappears.
asik1
- ram: 8gb
As VS has no particels engine at all, this is just another tool in the video toolboxRobertOZ wrote:Will try a reinstall later, problem is when hovering over a tab, the dialog box opens, but as soon as you move down to select a category, the dialog box disappears.
I also found Ver3.0 from 2003 on one of my disk, also stand alone and needs no installations.
I just run it here on W10.
I had limited usage of it, once I need a smoke to puff out a news encore so I used it.
**One thing I notice, 3.0 can output as frame sequence, but 13.0 do not.
3.0 has matrix, I don't see that in 13. 13 will not load 3.0 project
***OK Now 13 got the matrix.
Boris is also having a live webinar about how Particle Illusion free works. You need to register but can do so here: https://register.gotowebinar.com/regist ... 6325725455
There will also be a live streaming event Particle Illusion — From Preset to Polished Project Wednesday, June 24th @ 3pm EDT/12pm PDT on https://borisfx.com/livestream/?utm_sou ... ntent=live
- RobertOZ
That's a bit early Ken, 5 am in Melbourne, 3 am you local time
asik1
- ram: 8gb
10PM here. I hope they will upload it for, normal view...RobertOZ wrote:That's a bit early Ken, 5 am in Melbourne, 3 am you local time
TonyP
- motherboard: Gigabtye X570 Elite
- processor: AMD Ryzen 9 5950X 16core 32threads
- ram: 32GB 3200
- Video Card: Sapphire RX 6700XT 12GB
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
- Corel programs: VS2023, PSP2023, Aftershot 3
Boris has a lot of tutorials to get you started. Yes, the free version you can not import video or a clip into it. It's free. The plugin version works with software listed above. I have the full Boris Continuum 2020.5 in another editor I use.
I've found the PI to run really smooth on my computer, and there is so much that can be done with it.
