In PSP 3.11 (old memories) select and move (as duplicate) the selected zone.
Now in PaintShop Pro 2020... Ctrl+F to make the non-transparent part of the layer a floating selection (it will appear as a new layer with locked transparency).
How can I make that selection permanent? As in PSP 3.11 I'd like move selected area.
Thanks to all and forgive me for my terrible English.
Select and duplicate a selected area
andreone67_Ca
- motherboard: Asus ROG
- processor: i910900XF
- ram: 16mb
- Video Card: RTX2080i
- sound_card: Asus ROG
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: AOC G2460PG
- Corel programs: PaintShop Pro 2020
Re: Select and duplicate a selected area
Hello andre,
I guess you want to make the selection a separate layer, right? If so, there are a few ways:
1) Ctrl+Shift+P (same as Selections->Promote Selection to Layer) - it works for floating selections too (but you do not need to float it anyway)
2) After Ctrl+F, switch to the Pick tool, then click anywhere inside the selected area
3) After Ctrl+F, right-click on the floating selection in the Layers palette on the right, and from the menu that pops up select: Promote Selection to Layer
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
Andy2011
- motherboard: Gigabyte A520M S2H
- processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
- ram: 16 GB
- Video Card: Integrated Radeon Vega GPU
- sound_card: on board
- Hard_Drive_Capacity: 2500 GB
- Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
- Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Welcome (and even some of the posts from native English speakers are not always clear).
There was a recent post about moving selections https://forum.corel.com/viewtopic.php?f ... d62f901cbe
You say you have made a selection and promoted it to a floating selection - a new layer - and would like to move it. There are several ways to do that.
If you are still in selection tool, change the mode to 'Replace' and the cursor will change to 4 arrows within the selection. This allows you to move the selection.
If you change the tool to 'Pick', you can move the selection (a layer).
To make the moved selection (layer) permanent, you need to flatten the layers down. From the Layers menu, choose 'Merge' and choose the one you want.
Good luck.
Good luck.
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
andreone67_Ca
- ram: 16mb
Thank you for your answers
