Remove Background - Need advise
okyou
Video Card: onboard
sound_card: onboard
Hard_Drive_Capacity: 2TB
Corel programs: X9 Ultimate
Post by okyou »
Hello,
I have a photo I plan to replaced the sky. However, part of the sky was half covered by window shade as in pic1. Is there any way or trick to removed the sky background behind the shade so I can overlay another sky scene ? Thanks
migf1
operating_system: Windows 8.1
Re: Remove Background - Need advise
Post by migf1 »
Hi okyou,
in my opinion, the easiest way is to use Blend Ranges.
Here is a tutorial:
https://www.youtube.com/watch?v=TA7JF6u9HN8&t=666s
The link points directly to the part of the video that shows sky replacement (but there are also timestamps in the description, in case you wanna check out more uses of the Blend Ranges).
Tip: Don't bother to remove any background. Throw in the new sky as a new a layer (as shown there), adjust it & move it to your liking, use the Blend Ranges (again as shown there) and when you get satisfied with how it looks behind the shades, use the Eraser brush with low hardness and erase the unneeded parts of the sky.
Fast & easy. This for example took me literally less than 5 minutes: http://prntscr.com/sw8vyi
I hope it works for you.
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
okyou
Video Card: onboard
sound_card: onboard
Post by okyou »
Hello migf1,
I think this will do it.Thank you very much for you tip.
Best Regards
migf1
Post by migf1 »
You are welcome okyou,
let us know if you need more help!
Greetings!
