Filename in title adds colon and suffix?
terrypin
- motherboard: Asus Z170 Pro 4
- processor: Intel Core i7 6700K 4.0GHz
- ram: 32 GB
- Video Card: None - uses built-in graphics
- sound_card: HD onboard sound card
- Hard_Drive_Capacity: 4.256 TB
- Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
- Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
No doubt embarrassingly obvious but... why am I getting names like this in the PSP 8 titlebar? A file MotorControl.jpg as displayed in File Explorer and other image editors (including PSP 2018) is shown with a suffix ':2'. I assume somehow connected with layers - but there is only one.
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
Re: Filename in title adds colon and suffix?
Hi terry
I really have no idea what that is. I don't think latest versions show that colon (they show the current zoom percentage, along with the name of the active layer).
Good Unofficial PaintShop Pro Tutorials: Creation Cassel • Make Shop Pro • HEC Image Editing • LeviFiction PSP Basics
(plus my own Gimp & Stuff)
terrypin
- ram: 32 GB
Thanks @migf1. Just opened a new image and that too shows the same odd suffix.
After discovering the issue yesterday I checked Task Mgr and again found two instances of PSP 8. I ended the 'smaller' one. The issue remained. I haven't yet rebooted but will shortly.
The only other factor is that this file started as a WMF. I'll upload it here in case anyone wants to play with it.
https://www.dropbox.com/s/rly340cx8s7aa ... .wmf?raw=1
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
My installation of PSP8 does not do that.
- hartpaul
- ram: 8 Gb
If I load that file directly into PSP8 this is what I get and it does not look like what terrypin gets.
terrypin
- ram: 32 GB
Instead of rebooting I instead tried first using TM to close the current single instance PSP 8. After reloading, the suffix on all files has vanished. I conclude that it was nothing to do with layers and/or the WMF but is another consequence of my much discussed but AFAIK never satisfactorily resolved 'multiple instances' issue.
As for the WMF file, I don't understand them!
The original I uploaded was an export from an ancient program called CircuitMaker 2000 Pro. In PSP 8, although only 22 x 22 pixel size, it appears to contain maybe 200 or so vector layers.
Opened in IrfanView it comes up in readable form but with a pixel size of 1702 x 1064 instead of square. WMF is not one of IrfanView's types in the Save As dialog, so I used EMF. When opened in PSP 8 (or PSP 2018) that comes up as 1700 x 1063 and displays just a white rectangle.
For my purposes I used IrfanView to edit and resize it to the original square aspect ratio, 1243 x 1243, resized to show here:
Andy2011
- motherboard: Gigabyte A520M S2H
- processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
- ram: 16 GB
- Video Card: Integrated Radeon Vega GPU
- sound_card: on board
- Hard_Drive_Capacity: 2500 GB
- Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
- Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
I had a dim, distant memory of WMF (Windows Meta File?) and Powerpoint.
I copied (drag & dropped) the file into my old Powerpoint 2007 and converted the image to a Microsoft Drawing Object. It can then be ungrouped to the individual elements. E.G. a transisor is made up of a circle & lines.
A similar process can be done in LibraOffice Draw (free software and quite good). The step is to 'Break' the image (a context-level right-click command). Again the elements are available for editing.
EDIT - In PSP 2020 it opens (after asking for the image size). There is a single Vector layer with transparency but it is incomplete - e.g. missing circles round transistor junction. (I've added a white background to screenshot.)
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
- ehume
When one opens a .wmf with PSP7 or PSP8 one is given the option of declaring an image size. Try 2222 x 2222 instead of accepting 22 x 22.
terrypin
- ram: 32 GB
Thanks, hadn't spotted that!ehume wrote:When one opens a .wmf with PSP7 or PSP8 one is given the option of declaring an image size. Try 2222 x 2222 instead of accepting 22 x 22.
