VideoStudio Stutters Horribly on 4K Video
TexasNightOwl
- motherboard: Gigabyt X570 Master
- processor: AMD Ryzen 9 3900X 12 Core 24 Thread 3.8 to 4.6GHz
- ram: 32 GB
- Video Card: Gigabyte Aorus RTX-2060 Super
- Hard_Drive_Capacity: 3 TB SSD
- Monitor/Display Make & Model: LG 42 inch UHD monitor
- Corel programs: VideoStudio 2019 Ultimate
I have VideoStudio Ultimate 2018, 2019, and trial version of 2020. In each version, most of my 4K videos have to be Smart Proxied before they play on the timeline or as clip preview without Very, Very, Very severe stuttering. With HEVC on, it is less severe than with it off. But still severe either way. Don't really notice a difference between 30 & 60 frames per second because they both unusable. Even after proxy generated, if I use Single-Clip Trim or Multi-Trim Video it stutters so severely that I can't even edit the videos. The program sort of a waste when I can't even trim clips.
Since I am now starting to shoot mainly in 4K on my Samsung S9+, unless I can figure out why this doesn't work with multiple computers I am being forced to abandon Corel and go with Adobe or Resolve.
I had the problem on my $2,000 laptop and now I also have it on my new PC with AMD 3900X 12-core processor, 32 GB RAM, 2 TB NVMe 4th Gen PCIe SSD, Gigabyte Aurous RTX-2060 Super graphics card, LG 4K monitor. I have never been able to get VideoStudio to work with 4K videos. The laptop Windows 10, PC Windows 10 Pro.
Thanks for any help.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Re: VideoStudio Stutters Horribly on 4K Video
I routinely edit and render 4K video from both Sony and Panasonic cameras and don't experience the problem that you report. You ought to enable Smart Proxy and check that all proxy files have been created. Smart Render has nothing to do with editing.TexasNightOwl wrote:most of my 4K videos have to be Smart Rendered before they play on the timeline or as clip preview without Very, Very, Very severe stuttering.
tletter
TexasNightOwl
- ram: 32 GB
Yes, I meant Smart Proxy instead of Smart Render. And yes proxy files are generated for all the videos. I was looking thru some of my old notes, and Corel told me in the 2018 and 2019 versions that the proxy files are not used in Single-Clip Trim or Multi-Trim Video. STUPID!!! I just tried the 4K files in Adobe Premiere Elements ($$$ wise equivalent of VideoStudio) and they don't stutter, even without proxy files.
tletter
I use the Split Clip (scissors) tool to cut a clip into multiple clips and VS creates proxy files if Smart Proxy is enabled. Again I've not seen the stuttering that you're reporting if the proxy files have been created (check the Proxy File Manager to see that proxy files exist).TexasNightOwl wrote:Corel told me in the 2018 and 2019 versions that the proxy files are not used in Single-Clip Trim or Multi-Trim Video. STUPID!!!
Well if this other NLE is problem-free, easy to use, and does what you want then go for it, but again VS can definitely edit 4K videos without the severe stuttering that you're reporting.TexasNightOwl wrote:I just tried the 4K files in Adobe Premiere Elements ($$$ wise equivalent of VideoStudio) and they don't stutter, even without proxy files.
tletter
TexasNightOwl
- ram: 32 GB
That might explain why you don't see the problem. Proxy files are used when you use Split Clip in the main window. My workflow though is to watch the video and hit [ at the beginning of a desired sub-clip then ] at the end then have the video keep playing until the next sub-clip I want, at which point I do the [ and ] repeatedly thru the clip until I have extracted all the sub-clips I want. Much more efficient.tletter wrote: I use the Split Clip (scissors) tool to cut a clip into multiple clips and VS creates proxy files if Smart Proxy is enabled. Again I've not seen the stuttering that you're reporting if the proxy files have been created (check the Proxy File Manager to see that proxy files exist).
Even you said that you don't see stuttering "if the proxy files have been created." Which means without the proxy files that your Split Clip would not go so well? With a $500 CPU chip, $350 motherboard, $300 SSD, $500 graphics card, $300 DDR memory, there is NO REASON that even Smart Proxy needs to be on. And, yes, I even look at the proxy files in the proxy directory.
They don't have all the bells and whistles as VideoStudio. It seems stupid that I would have to trim my videos in another program, export, probably with some compression loss, then work with them in VideoStudio before exporting again with more compression loss.tletter wrote: Well if this other NLE is problem-free, easy to use, and does what you want then go for it, but again VS can definitely edit 4K videos without the severe stuttering that you're reporting.
I don't understand why they would advertise 4K Display and 4K support, but not fully support it (e.g. Multi-trim).
tletter
I don't find using the Multi-trim Video feature in my workflow to be more efficient but if you do fine. Any workflow is a personal preference and not a guarantee of efficiency.TexasNightOwl wrote:Much more efficient.
Using the Multi-trim Video feature on 4K seems to work fine unless you Zoom-in to the max. In any event, if a proxy file exists before you use the Multi-trim Video feature, then the trimmed clips still use proxy on the timeline. If the proxy didn't exist before you use the Multi-trim Video feature, then create proxy files afterwards.TexasNightOwl wrote:I don't understand why they would advertise 4K Display and 4K support, but not fully support it (e.g. Multi-trim).
The price you paid doesn't tell us what type of CPU you're using. In any event, NLEs such as Adobe Premiere Pro and daVinci Resolve support the use of proxy files so they must have some merit. However, if your other NLE doesn't need them to satisfactorily edit 4K video then good.TexasNightOwl wrote:With a $500 CPU chip, $350 motherboard, $300 SSD, $500 graphics card, $300 DDR memory, there is NO REASON that even Smart Proxy needs to be on.
tletter
TexasNightOwl
- ram: 32 GB
It is more efficient because the clip keeps playing, so you just have to hit [ key to start another sub-clip and ] to end it, repeating until done with that clip. Your way, I believe, you have to stop after the second split, select the part you don't want between the 2 splits, then delete it.tletter wrote:I don't find using the Multi-trim Video feature in my workflow to be more efficientTexasNightOwl wrote:Much more efficient.
Here is email from Corel saying the idiots didn't apply proxy to multi-trim:tletter wrote:In any event, if a proxy file exists before you use the Multi-trim Video feature, then the trimmed clips still use proxy on the timeline.
Vommina Mounika (Corel)
Sep 17, 13:07 EDT
Hello Bill,
Thank you for your patience.
Sorry for the delayed response. I checked with our higher level.
I am sorry to inform you that, smart proxy regretfully cannot be applied to multi or single trim elements.
Vommina
Corel Customer Support Services
That is in the original post. AMD Ryzen 9 3900X 12-Core/24-Thread 3.8GHz/4.6GHz. Aorus RTX 2060 Super graphics card. GIGABYTE AORUS NVMe Gen4 SSD 2TB M.2 2280 PCI-Express 4.0 x4 3D TLC. On a 4th Gen PCIe motherboard (i.e. PCIe is double the bandwidth as the old 3rd Gen PCIe used on Intel motherboards). 32 GB DDR.tletter wrote:The price you paid doesn't tell us what type of CPU you're using.
I tried both NVIDIA CUDA and Intel hardware acceleration.
tletter
On my installation of VS2018 as previously described, proxies are still used on trimmed clips on the timeline after use of the Multi-trim Video feature.TexasNightOwl wrote:Here is email from Corel saying the idiots didn't apply proxy to multi-trim:
Perhaps you could update your profile listing "processor: I7-8550U" which isn't a particularly high performance CPU.TexasNightOwl wrote:AMD Ryzen 9 3900X 12-Core/24-Thread 3.8GHz/4.6GHz. Aorus RTX 2060 Super graphics card. GIGABYTE AORUS NVMe Gen4 SSD 2TB M.2 2280 PCI-Express 4.0 x4 3D TLC.
tletter
TexasNightOwl
- ram: 32 GB
Yeah, AFTER. It needs to be DURING so Multi-trim can be used on 4K video.tletter wrote: proxies are still used on trimmed clips on the timeline after use of the Multi-trim Video feature.
Good point. That is my laptop CPU...and it was Ok when I got it couple years ago.tletter wrote: Perhaps you could update your profile listing "processor: I7-8550U" which isn't a particularly high performance CPU.
What I am wondering though, is why does the video need to be proxied at all on such a fast GPU and 24 thread CPU? Even my slow laptop can play 4K video in Windows Media Player without stuttering. Multi-trim, clip player (no effects even possible), and project player can't be doing much more than playback if no effects have been applied. What stupid crap is Corel doing to make playback stutter?
Do you get stutter if you haven't created proxies (e.g. you play 4K from the media tab instead of from the timeline)?
renebeau
- motherboard: Asus P8Z77-V LK
- processor: core i7 3770k at 3.9 GHz
- ram: 32 GB
- Video Card: Asus GTX 1660 Super 6 GB
- Hard_Drive_Capacity: 7.5 TB
- Monitor/Display Make & Model: LG 24'' and Asus 24'' Full HD LCDs
- Corel programs: VS 2019 Ultimate
I have exactly the same experience. The GUI is extremely laggy and the export not fast. I downloaded Shotcut yesterday and it beats VideoStudio hands down regarding GUI speed and export, even on my system which is not the most powerful (i7 3770K @ 3.9 GHz, NVidia GTX 1660 Super, Asus mobo, NVNe SSD 3rd gen).
I will not buy the next version of VS.
CU
CU
tletter
There is no comparison between a video player playing a single clip and a NLE that is accessing and playing multiple clips which may also include clips playing simultaneously if overlays are being used.TexasNightOwl wrote:What I am wondering though, is why does the video need to be proxied at all on such a fast GPU and 24 thread CPU? Even my slow laptop can play 4K video in Windows Media Player without stuttering.
I assume that by "media tab", you're referring to the Preview Window in the Edit workspace. In the Preview Window, VS plays 4K videos that haven't been added to the Timeline just as a standalone video player does, i.e. no stuttering. In my experience, stuttering comes about when a large number of video clips are on the Timeline and proxies haven't been created. However, even if proxies have been created and everything is on a SSD, moving about the Timeline on a long and complex VSP can be slow and frustrating.TexasNightOwl wrote:Do you get stutter if you haven't created proxies (e.g. you play 4K from the media tab instead of from the timeline)?
tletter
tletter
If that is your only criteria then that may be the case. However, most users also value ease of use, the GUI, and the feature set.renebeau wrote:I downloaded Shotcut yesterday and it beats VideoStudio hands down regarding GUI speed and export
tletter
TexasNightOwl
- ram: 32 GB
Therein lies the problem. With 2 different computers, with VideoStudio 2018, 2019, and 2020 most of my 4K videos stutter there. That is why I said it can't even play a clip from the Media tab when there is no processing to do on the video. BTW, it is called Media tab because if you mouse over the tabs under the Edit tab, they are named Media, Sounds, Templates, Transitions, etc.tletter wrote:In the Preview Window, VS plays 4K videos that haven't been added to the Timeline just as a standalone video player does, i.e. no stuttering.
Not for me. No clip on the timeline...stutter when clip played in media tab until proxy created. Proxy created, right click and select Single Clip Trim...stuttering even though still nothing in the timeline. Drag a 30 second 4K clip on the timeline will stutter until proxy file generated...even though it only thing on timeline and still nothing being applied to it...no cuts, no filtering, no anything. Once proxy file generated it will play without stuttering. Right click on timeline and select Multi-trim Video...it stutters real bad even though proxy has been generated, no cuts, no filtering, no other clips on timeline, no anything.tletter wrote: In my experience, stuttering comes about when a large number of video clips are on the Timeline
BTW, you might want to give Multi-trim Video and Single Clip Trim a try, they are very efficient for non-4K videos.
TexasNightOwl
- ram: 32 GB
I tried doing an export in the VS Ultimate 2020 version to check speed. I used a 3 minute UHD, 30 fps video dragged to the timeline, rotated 90 degrees and exported as 1080p 30 fps (since trial version won't allow 4K export).renebeau wrote:The GUI is extremely laggy and the export not fast.
I have a Gigabyte Aorus version of the NVIDIA RTX-2060 Super video card, so I tested CUDA compression compared to NO Hardware compresssion, then to Intel just for comparison sake.
In all cases, I had power plan set to High Performance,
the CPU utilization was 14 to 18%, and
the GPU utilization was 9 to 12% regardless of acceleration settings
With NO hardware acceleration, the export time was under 14 minutes 31 seconds. I say under because I missed the end and hit the stop button on my phone clock when I noticed it stopped.
With NVIDIA CUDA acceleration 14 minutes 3 seconds. Less than 28-second savings!!!!
With Intel Quick Sync Video acceleration 13 minutes 59 seconds. 4 seconds FASTER than the acceleration for my video card type!!!!
I thought I would like the Highlight Reel to be able to see videos easier by date and faces, but it crashes on import when it reaches a little over 4,000 files. So another feature that is worthless to me.
I like all the bells & whistles of Corel products. But I wish they would take a break from adding stuff most people never use, and some people only rarely use, and make their products work for more people!!!
