where did did transparent go when I move a selection?
adgorn
motherboard: dell laptop
processor: intel i7
ram: 40gb
Video Card: unknown
sound_card: unknown
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: dell laptop
Corel programs: PSP
Post by adgorn »
I'm still learning the ropes on PSP 2020 and finding that to be a challenging and time consuming task.
So I create a selection. Then I drag (move) it. I believe that used to reveal the checkerboard transparent canvas. But now it reveals the Background and fill color. I think that is a change in behavior, but not sure if I'm just mixed up?
If I close and reopen my image to start over, then first use the Eraser tool, it does reveal the transparent layer. Then if I use a selection tool and move the selection, it does reveal the transparent layer now.
So I'm confused as to what's going on. Thanks for your pending help!
migf1
operating_system: Windows 8.1
Re: where did did transparent go when I move a selection?
Post by migf1 »
Hi adgorn!
How do you drag the selection? I assume with the Pick tool. If so, PSP's default behavior is to promote the selection to a new layer automatically. Actually it doesn't let you drag directly, because as soon as you click (for dragging) the selection gets promoted to a new selection, and you have to click again in order to drag. I'm not sure when and if it was different in older versions, but that's how it works since at least version X7.
If you want to drag the marching ants of the selection instead, then you can do it by dragging with the right mouse button (before the promotion takes place). If you want to transform the marching ants themselves, you can enter the selection Edit Mode. Here is a short tutorial about that: https://youtu.be/uBYyPa6kjRA
Lastly, if you operate directly on the background layer of a png image, transparency may not show when erasing if you have not Promoted the Background layer first (if you haven't, you will most probably get whichever color is currently set as your background color, in the materials palette).
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
Andy2011
motherboard: Gigabyte A520M S2H
processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
ram: 16 GB
Video Card: Integrated Radeon Vega GPU
sound_card: on board
Hard_Drive_Capacity: 2500 GB
Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Post by Andy2011 »
As migf1 has said, there are lots of variations to moving selections. Another one is:
a) make a selection (on the background layer say) using one of the selection tools, e.g. rectangle, and mode 'add'
b) change the selection mode to 'replace'
c) using the selection tool - the indicator changes to four arrows - drag the selection
e) the selection is moved and a white area remains.
If, before making the selection, you promote the background to a layer (right click on layer palette), a transparent area will remain on moving the selection in (c) above.
Confusing - yes!
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
adgorn
processor: intel i7
ram: 40gb
Video Card: unknown
sound_card: unknown
Corel programs: PSP
Post by adgorn »
Thanks both.
migf1 - I see how using the Pick tooI promotes the selection. I didn't know about the right mouse button, so thanks for that tidbit.
Andy2011 - your scenario is what I am seeing, with the four arrows. But when drag, it reveals the Background color not the checkerboard transparent "color" taht I beleive I used to see. So I must have changed something to cause that to happen. That's what I am trying to figure out how to fix.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
In Andy's step e) you will only get the white area if that is the Background color.
If you use one of the selections and have it set to Replace then you will have a 4 sided arrow as your cursor and when you left click and drag to move the selection it will move and leave whatever background color you have selected in your materials palette .
If you first Promote Background Layer then you will get the transparent checkerboard pattern.
If you use any eraser tool then it automatically promotes the Background to a raster allowing transparency.
If you have made your selection and then switch to the Pick tool and left click drag it will make a promoted copy of the selected area and also automatically promote the Background layer to a raster.
If you have made your selection you can right click the layer and promote the selection to a layer and leaving the Background layer intact. You can also drag that Promoted Selection to a blankspot on the canvas and a cropped copy will be made there .
Lots of fun things you can do. Just play around and observe if the layers are Background (no transparency ) or Raster (transparency allowed) .
adgorn
processor: intel i7
ram: 40gb
Video Card: unknown
sound_card: unknown
Corel programs: PSP
Post by adgorn »
I get it now. I wasn't grasping the difference between a Background vs a Raster layer as well as not noticing how the promoting was happening. All of you have been very helpful, Thank You!
