Occasionally I have a photo file which contain an Exif orientation tag with the value: Rotate 90 CW
When I view it with several image viewers (e.g. XnView) then the photo is NOT (automatically) rotated. So I have to view it from left side.
When I load it into PSP X2 then it is displayed "correctly".
So one of the tools must work incorrectly.
First of all I want to get the interpretation of the Exif orientation tag:
From my point of view the photo is PHYSICALLY saved with an angle of 90deg CCW and needs for correct viewing an on-the-fly rotation of 90deg CW?
Correct?
Why do all the image viewers not pay attention to this instruction?
Or is PSP wrong?
How do I tell PSP to set orientation tag to 0deg and rotate (and save) the photo physically accordingly?
Peter
Interpretation Exif orientation tag?
Andy2011
- motherboard: Gigabyte A520M S2H
- processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
- ram: 16 GB
- Video Card: Integrated Radeon Vega GPU
- sound_card: on board
- Hard_Drive_Capacity: 2500 GB
- Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
- Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Re: Interpretation Exif orientation tag?
Image rotation is often a problem - worth looking at this
https://www.impulseadventure.com/photo/ ... ation.html
If you open the image information (SHIFT/I) in PSP there are options to change things under EXIF. Also, on saving it is possible to discard the EXIF data (Save As / Options/ tick box at top).
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
