Hi there,
I understand ParticleShop is designed to run in 64-bit and I can launch it within Photoshop CC. My main photo editor is PSP X9 32-bit and I was wondering if there's a modified NIK script from a while back that would work nicely with ParticleShop? I did a search and found few old threads on the topic of running NIK scripts but not Painter ParticleShop.
Thanks!
Script to run ParticleShop
patara
- motherboard: ASUS Prime Z690 DDR5
- processor: Intel i7-12700K CPU 12 Core
- ram: 32 GB
- Video Card: GeForce GTX 1060 GI Gaming 6G
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
- Monitor/Display Make & Model: Dell U2715H
- Corel programs: PSP7 to PSP 2023
Re: Script to run ParticleShop
An edited Nik script works for me in PSP 32bit with ParticleShop.
I changed the exe file address to the ParticleShop exe file in the Corel folder.
On saving it gives the option to merge with layer or save brush strokes only.
As I have not sorted out the script to save with transparency it saves on a white layer if brush strokes only is chosen.
It does save back to PSP.
As PSP 64bit is my default I don't need to use the script.
I've tested many graphic apps and plugins using an edited Nik script and most work.
I suggest you give it a go yourself and edit the Nik script exe file address section and see if it does what you want. Otherwise perhaps someone in the Forum's PSP Script section can help you if you require transparency.
Jan Shim
- motherboard: ASUS ROG Maximus V GENE
- processor: Core i7-3770K 4.4GHz
- Video Card: nVidia GeForce 2GB GTX 660
- Monitor/Display Make & Model: Dell UltraSharp U2713H
Thanks! Works great
