Removing and substituting objects.
Dancing Cat
Video Card: NVIDEA GTX 1050 T
sound_card: NVIDIA Virtual Audio
Hard_Drive_Capacity: 3Tb
Monitor/Display Make & Model: Sharp 32" TV Screen
Corel programs: Corel PSP 2021
Post by Dancing Cat »
Is it possible with PSP to remove an object from a picture without having to carefully trace around it? I want to remove a flag from an illustration and replace it with a different flag.
Thank you.
migf1
operating_system: Windows 8.1
Re: Removing and substituting objects.
Post by migf1 »
It depends on the background. Your best bet is the Magic Fill I guess.
Trace your subject losely, say with the freehand selection tool, then use the Magic Fill button on the horizontal toolbar.
Like so: https://gyazo.com/bcb30c3a4c885572466467ff81da34b8
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Dancing Cat wrote:Is it possible with PSP to remove an object from a picture without having to carefully trace around it? I want to remove a flag from an illustration and replace it with a different flag.
Thank you.
Could you post the image here?
Different solutions are possible but vary upon the context.
Dancing Cat
Thanks you both for your suggestions, migf1 I will try what you suggest thank you
Jean-Luc I have attached the illustration for you to consider, thank you
Best wishes to both of you.
Jean-Luc
Post by Jean-Luc »
Is your other flag folded the same way?
Dancing Cat
Unfortunately not, it will require some post-work but I'll worry about that when I've managed to delete the current flag. I will search for a flag that almost conforms in shape.
migf1
Post by migf1 »
Oh it's not gonna be easy to remove that flag, Dancing Cat. Unless you have a very similar flag to replace it with, there is stuff you need to recreate (stuff now covered by the flag). You can try with the clone tool, or similar ones like the scratch remover. Even if you select the flag manually, you still have to recreate areas it covers, if the replacement flag doesn't cover them too.
I think It is much easier to change the shape of the flag to something bigger, and probably less folded, so it can then host other flags easier.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Is this something like what you are after?
After finding a public domain flag
1. I used the Selection Tool > Auto select.
The flags stand out so much that most of your selection is done for you.
2. I used Selection Tool > Freehand Selection > Point to Point > Add setting to add areas left out and then changed to Remove to get rid of excess material.
3. Promoted the layer to Raster, invert selection and delete .
4. Selections > None leaves you with your new flag on a transparent layer.
For your image
5. Used the Selection Tool > Auto Select and same procedure (steps 1 and 2) to get your flag selected.
6. Saved Selection to Alpha Channel (just in case) and then saved as a pspimage. (always do regular saves in case of blackouts , stuffups etc).
So I had the US flag on a transparent layer and your image with your flag selected . Switch your tool to the Pan Tool .
7. I then copied the US flag Right click copy , made your image active and Right click > Paste > Into Selection
That placed the US flag mostly over the Union Jack.
8. Now I switched to Mesh Warp tool (hidden beneath the Warp Brush) and by moving nodes around managed to cover all of the Union Jack with the US Flag.
9. Saved image as a pspsimage (in case I needed to come back and use it again but with a different flag).
10. Merged all and that posted was the final.
Jean-Luc
Post by Jean-Luc »
hartpaul wrote: that posted was the final.
Excellent!
Dancing Cat
I forgot to mention. I can reproduce the picture without the flag would that make it easier?
migf1
Post by migf1 »
Yeah, in my opinion that would make things a lot easier, because then you can keep just the pole, and simply paste in another flag as a new layer. Using the Pick too, you can re-scale the new flag and move it in place.
Dancing Cat
I now have the picture without the flag. I have remodelled a drum-stick to form the pole. Now I cannot see how to post (attach) the new image...............OK found it.
Andy2011
motherboard: Gigabyte A520M S2H
processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
ram: 16 GB
Video Card: Integrated Radeon Vega GPU
sound_card: on board
Hard_Drive_Capacity: 2500 GB
Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Post by Andy2011 »
migf1 wrote:Yeah, in my opinion that would make things a lot easier, because then you can keep just the pole, and simply paste in another flag as a new layer. Using the Pick too, you can re-scale the new flag and move it in place.
... and don't forget the shadows - this is often the give-away for a modified picture.
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
Dancing Cat
Thanks migf1. I will rely on the shadow of the previous object, it'll still be there.
migf1
Post by migf1 »
Very nice! It should be easy now to add any flag as a new layer into the image, then re-scale and reposition it, to "attached" it to the pole. And as Andy pointed out, add a corresponding shadow for it.
PS. Oh, we were cross-posting :) You are very welcome Dancing Cat.
