psp opening multiple images separately
miltk
Video Card: nvidia gforce 1030
Hard_Drive_Capacity: 250-500
Monitor/Display Make & Model: LG 32MA68HY-P 32-Inch IPS Monitor
Corel programs: psp x6 16.0.0.113
Post by miltk »
when i try to open more than one image, psp opens each separately rather than all together. this never happened before and just started happening recently.
w7 pro, psp5
migf1
operating_system: Windows 8.1
Re: psp opening multiple images separately
Post by migf1 »
Can you please clarify "separately" and "all together"?
AFAIK, each image in its own window is the default behavior when opening multiple images. If you mean each image being a separate layer in an existing pic, then you need to drag them into the layers palette of the already open picture (drag them right above any of the existing layers).
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Post by Cassel »
Or maybe you mean that you can only see one at the time, instead of seeing them all at once. If that is the case, go to Window > Tabbed Document and uncheck that.
Cassel
https://scrapbookcampus.com
miltk
Post by miltk »
migf1 wrote:Can you please clarify "separately" and "all together"?
sorry. did not know how to explain it. if I open say multiple images, whether at once or any additional images, another psp will open with each image, not one psp with multiple windows. in other words one psp per image. I saw nothing in preferences....can it be a windows7 issue?
windows7 pro , 64bit
miltk
Post by miltk »
Cassel wrote:Or maybe you mean that you can only see one at the time, instead of seeing them all at once. If that is the case, go to Window > Tabbed Document and uncheck that.
this is what's happening. where is this "window>tabbed document"
here's an image when i open 2 images. note the window tab. i don't see a "tabbed document" this is not where you mean is it?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Tabbed document is a new feature in the new versions of PSP. You are using a very old version.
You say "When I open 2 images" but you don't say how you open the images.
Do you open Windows Explorer and click on the images in a folder?
Do you open them inside PSP with File/Open?
In this last case, if you select the 2 files and open them, do you see them both on your workspace?
miltk
Post by miltk »
Jean-Luc wrote:Tabbed document is a new feature in the new versions of PSP. You are using a very old version.
when i hilite multiple image files at once and "open". like say i have some images on the desktop..or i open a folder with multiple image, select a few images, and then hit "open". or, as per your example, if i go to explorer, go to a folder, hilite a few images and right click "open". i do not open files within psp unless i am browsing. psp is the default program to open all images, so i just click on an image, or if i intend to open multiple images, i select and right click open.
if i open psp first, browse to a folder and hilite several images, they all open in tiles. but as i said this does not happen if i open images thru explorer or any other way
btw, if i make corel pspx6 the default program, it's fine. x6 will open multiple images. but i don't like corel. i can't see the menu - too small
this started happening a week ago
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Try Open with one image.
Then open a folder with other images and choose the number of images and drag and drop them to the PSP 7 workspace.
That should act as a workaround and keep them all in the same opened PSP7.
I know up to PSP 8 if you had the jpg images associated with that version of PSP would could open multiple instances of PSP8 and have them operating and operate by switching from one window to the other.
However you don't want multiple versions of the same program running and need them to open in the one version.
miltk
Post by miltk »
hartpaul wrote:Try Open with one image.
Then open a folder with other images and chhose the number of images and drag and drop them to the PSP 7 workspace.
do you think this is a psp issue or a windows issue
hartpaul
ram: 8 Gb
Post by hartpaul »
It may be a setting in Windows that allows an image to open with one click rather than a double click.
https://answers.microsoft.com/en-us/win ... b599b31bf5
miltk
Post by miltk »
i can open psp then drag multiple images. i cannot drag multiple images to a psp shortcut....an annoyance. this should not be happening in the first place. i should have used a restore point when this all started.
miltk
Post by miltk »
i did something i should have done before i wasted your time. i reinstalled psp5. :oops: :oops: :oops:
call me an idiot
thx all
hartpaul
ram: 8 Gb
Post by hartpaul »
Ok you are an idiot. Satisfied now? :wink: :) :D :lol:
You used the Corel 'help'line solution :D :D :D
