I'm fairly new to Videostudio 2020. I'm trying to add a drop shadow using the NewBlue Video Essentials pack that downloaded with VideoStudio but it has no effect. I tested a few NewBlue effects on the same image and they worked fine.
I watched a video that covered Drop Shadow and Chroma Key. The Chroma Key was only when using a video overlay where the person doing the tutorial needed to adjust the chroma key.
In any case, the ChromaKey filter also had no effect - though it was not the appropriate effect for this object. I just added it to test it.
Any thoughts on making this work.
Thanks,
D Levy
NewBlue Drop Shadow not working
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: NewBlue Drop Shadow not working
Confirmed, NB Drop Shadow is not working, none of the presets are active, neither can you create your own drop shadow, will submit a bug report
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
No so quickly...RobertOZ wrote:Confirmed, NB Drop Shadow is not working, none of the presets are active, neither can you create your own drop shadow, will submit a bug report
Have you tried to dropshadow on a png file?
In order to have it to work on video with the NB chroma key, you have to apply the full white mask first. and than ** Done on VS2018
Panasonic X900m, VXF1
dlevy
- Corel programs: VideoStudio 2020 Ultimate
I tried a drop shadow on both a png and jpg. Neither works. We added a shadow in a custom motion and that works.
