psp2020 pic to painting loading error 1606 network EN
inq
operating_system: Windows 8.1
Post by inq »
Hi, upgraded from psp8 to psp2020, chose 32 & 64. . Works great BUT. . .
Wanted the pic to painting. .
So chose 32v then extras then more plugins & selected p t p
Downloads ok, starts to install then get the error 1606
Still a prob in 2020?
Have uninstalled, cleaned with corel clean, reinstalled. . But same end result
Any other solutions?
Re: psp2020 pic to painting loading error 1606 network EN
inq wrote:Wanted the pic to painting. .
Welcome to the forum!
If by "32v" you mean you chose the 32 bit version of PSP, then Pic-to-Painting will not install in the 32 bit version as it is a 64 bit program. That's one of the reasons when installing PSP that you are recommended to install both 32 and 64 bit versions. A lot of users have collections of "old" but still very effective plug-ins which will only work with 32 bit, but P-2-P is not one of them. Like a lot of more modern plug-ins, it will only work in the 64 bit version of PSP.
If I have misunderstood your problem, there is an extremely long thread about Pic-to-Painting which may address your problem: https://forum.corel.com/viewtopic.php?p=360487#p360487
inq
Post by inq »
Thanks for info Ken
Initially tried in 64 bit. . Got the error. . Searched these boards and found the method said above. . It was said to resolve it for the poster (post was in 2018). . Will repeat and go for the 64 bit.
Link is helpful, thanks, will read more whilst having another go
Cheers for now
inq
Post by inq »
Is the EN folder permissions correct as is. . . or does it need permission to write (tick the write box)?
Read & execute = ticked
List folder content = ticked
Read = ticked
Write = not ticked
(the error is for \Plugins\EN folder)
Cheers
image of EN folder permissions
Andy2011
motherboard: Gigabyte A520M S2H
processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
ram: 16 GB
Video Card: Integrated Radeon Vega GPU
sound_card: on board
Hard_Drive_Capacity: 2500 GB
Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Post by Andy2011 »
Pic-to-Paint installs an app in Windows as well as the plug-in.
I had trouble intalling Pic-to-Paint (V2 - 64 bit) last year when I upgraded to PSP2020. The install was giving an unhelpful error message part way through. Corel support was equally unhelpful (usual advice of uninstall PSP, clean, reinstall).
In the end I found that the old version of Pic-to-Paint (v1 = 32 bit) was the problem. I had to uninstall it via the Windows Apps & Features control . Then the install of Pic-to-Paint V2 worked fine - it required Administrator permissions to install.
If you haven't had Pic-to-Paint before this is probably irrelevant but a failed install may have left a shadow behind so it's worth checking in the list of Apps.
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
inq
Post by inq »
Thanks for info Andy. . .
I have just downloaded another plugin (from AKVIS). . . it is 64-bit and came wrapped in InstallShield Wizard (same as PSP pic-in-painting). . . it downloaded and installed just fine 8)
Soooo
:?: PSP method and/or info, seems suspect
:?: Anyone know, where the previous versions are to be found. . so be to downloaded
:?: Or a direct download page for the latest 64-bit (so i can chose my own download folder and do the file allocation myself)
what an aweful experience :shock:
Andy2011
ram: 16 GB
Post by Andy2011 »
inq wrote: :?: Anyone know, where the previous versions are to be found. . so be to downloaded
I suspect Corel control access to Pic-to-Paintig to try and prevent illicit copying. The flaky installer means getting help from Corel's Support Desk (an oxymoron in my experience).
inq
Post by inq »
Yep, I kinda understand the protection of the download apage. . . even like the idea that one reaches it through a licenced product menu. . .
Just the installer prog seems utter rubbish (over controlling where the files will be sent etc)
Think I'll just cancel this PSP update n plugin route. . .
Needed a pic to painting software ability for a small project. . . not an epic saga of wierd "get it to load" puzzles
I've now sourced some other stand alone programs to do the job. . . loaded them. . and done the job!! 8)
Heyho
thanks again for time and thoughts to consider.
