Select Audio Track in VS2019
mosscomes
- motherboard: Intel
- processor: I-7 8700
- ram: 16 GB
- Video Card: Intel
- sound_card: Intel
- Hard_Drive_Capacity: 3 gb
- Monitor/Display Make & Model: HP 2009m
- Corel programs: Paintshop Pro
I have video that I want to edit. It has two audio tracks and I want to use the second track instead of the first. It defaults to the first. Is there a way to either select the second track or delete the first within vs2019?
mosscomes
- ram: 16 GB
- Video Card: Intel
- sound_card: Intel
Re: Select Audio Track in VS2019
This doesn't allow selecting the second track. I've checked and unchecked all combinations. Defaults to the first.
pvreditor
- processor: Intel i7
- ram: 24GB
- Hard_Drive_Capacity: 2TB
Can you explain what you mean by "It defaults to the first"? If a track has two audio channels, one should play from the left speaker and one should play from the right speaker. Do you want to put the left channel on both the left & right speakers? If that's not what you're trying to do, please explain in more detail.mosscomes wrote:I have video that I want to edit. It has two audio tracks and I want to use the second track instead of the first. It defaults to the first. Is there a way to either select the second track or delete the first within vs2019?
mosscomes
- ram: 16 GB
- Video Card: Intel
- sound_card: Intel
It has two tracks. First one is Spanish, Second is English. I can only find the Spanish track in the program. I can find both tracks in VLC player and select.
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Try Audacity.mosscomes wrote:It has two tracks. First one is Spanish, Second is English. I can only find the Spanish track in the program.
tletter
With Audacity you should be able to strip out the English audio, make it into a separate .wav or mp3 file. Then insert it with the video in VS. You'd need to mute the existing Spanish audio, of course.
