Straightening Tool reduces 4.18MB photo to 806KB photo
Phil47
motherboard: ASUS Z170-P DDR 4
processor: i-5 6600K OC
Video Card: GTX960
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: Asus MX279
Corel programs: PSP X6 PSP X9 PSP 2018
Post by Phil47 »
I just noticed that when I straightened the horizon just a small amount on my sunset photos tonight there was a massive drop from 4.18MB to 806KB.
This is from only a slight correction to the horizon.
Am I doing something wrong?
Is this normal?
This is using the PSP Pro 2020.
Thanks.
Tell the truth....but gently.
Phil.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Straightening Tool reduces 4.18MB photo to 806KB photo
Post by Jean-Luc »
Hi Phil47,
verify your JPEG compression rate when saving.
Set it to 10 or less.
(Use "Save as" for checking the rate)
Phil47
Video Card: GTX960
Post by Phil47 »
Thanks Jean-Luc. It was at quite a bit over 10 so I reduced it to below 10 as you said.
Phil.
Jean-Luc
Post by Jean-Luc »
If you want to retain the maximum size (Best Quality), go for 1. :)
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Better yet, save it in a lossless format like .pspimage, PNG or TIFF. You don't need .jpg for almost any use because even PNG or TIF can be printed at any print shop, and PNG (not sure about TIFF) can be displayed on a web page if you are creating websites. Only use .jpg if you actually need to keep the file size small for some applications - which might include a website. :-)
JoeB
Using PSP 2019 64bit
Phil47
Video Card: GTX960
Post by Phil47 »
Thanks JoeB.
I'll look at that .
Phil.
Phil47
Video Card: GTX960
Post by Phil47 »
I have just found out why the cursor on the Save thing was set so apparently low, because when I want to publish to Ausphotography they want a photo that is 400kb or less.
So when I just resized some bird photo they came out as 800kb or twice the allowable size and wouldn't upload so I had to resize them all again at a different setting.
Phil.
Jean-Luc
Post by Jean-Luc »
If you want to control the JPG Kb size, go to Save As:
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
In addition if you have an image that is a set pixel size and you can't reduce its Save As size to your limits then you can try and soften background material using a soften brush.
This helps to occupy a smaller Save As size without causing compression pixelation in the main subject. The more detailed the background the more information has to be saved and the larger the Saved Ss size becomes.
jorgensen
Post by jorgensen »
Phil47 wrote:I have just found out why the cursor on the Save thing was set so apparently low, because when I want to publish to Ausphotography they want a photo that is 400kb or less.
Instead use File->Export->JPEG Optimizer.
