Color correction for thoriated lenses
jlovda
motherboard: Dell XPS 8700
processor: i7-4790
ram: 20 GB
Video Card: GTX 1050 Ti 4GB
Corel programs: PSP Ult. 2021, 2020, 2018
Post by jlovda »
I have many slides that used my Canon FD 35mm f/2 lens (w/ the concave front element). It used thoriated glass and the pictures have a distinct yellow/brown cast to them. I have fiddled with some of the PSP2020 color adjustments but can't neutralize the color. Does anyone have a "formula" they use to correct this? It seems to be a well known problem but I have never seen a fix.
https://www.flickr.com/photos/79976134@N07/16708441449/
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Color correction for thoriated lenses
Post by hartpaul »
Try Fade Correction Adjust > Color > Fade Correction
Then White Balance Adjust > White Balance and use the Smart Select by zooming in to the conductors white color and clicking on that . You could also try Levels to improve the contrast a bit.
Looks like was taken on an overcast day (no shadow for conductor) so would expect it to be a bit on blue side.
migf1
operating_system: Windows 8.1
Post by migf1 »
Good tips by hartpaul!
You may also try the Curves or Levels Auto buttons: https://gyazo.com/2cef1edff8fc02be33f8e40cfedbd5e6 (you should Reset it before trying a different button). The Contrast button affects only the Luminocity (lightness), Color button affects only the Hue & Saturation, and Levels button affect all 3.
However, if you like to have a more precise control and you don't mind going a little more advanced, have a look at this video: https://youtu.be/QhPteAOSe3U
It goes a little crazy for marking the exact 50% gray, black and white points, but if you already know which areas on your photo should be neutral gray (or black, or white) you can skip directly to the 1-point or 3-point correction sections of the video (there is a timestamps index-table in the description of that video, select SHOW MORE to see it).
The gray point is usually giving the more balanced colors, but try also black or white points. Also try more than 1 areas on your photo for each point (again, you have to Reset after each try).
Nice photo btw!
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
jlovda
processor: i7-4790
ram: 20 GB
Post by jlovda »
Thank you all! I have a lot to learn here so it's now time to roll up my sleeves.
John
TimW
motherboard: ASUS M5A99FX
processor: AMD FX8350 8 core 4.0GHZ
Video Card: AMD Radeon HD 6900 Series
sound_card: On Board
Hard_Drive_Capacity: 256GB SSD
Monitor/Display Make & Model: Dell UltraSharp U2412M 24"
Corel programs: PSP X8, Knockout 2
Post by TimW »
After doing what migf1 suggested, go to HSL (Hue, Saturation, Lightness), and bump up the red colors to about 40 or 50.
