Woohoo! That worked great. Now I've got rules ("guides") in my toolkit.migf1 wrote:You are very welcome Paul, I am glad it proved helpful.
You can create guides by dragging the mouse starting it from within a ruler (View->Rulers, if you don't have them visible). Like this: https://gyazo.com/d024bae9f92cfd7db844a23661b1cd64
Once created, Rulers can be moved by dragging their handles inside the ruler area. You can even right-click on their handles and manually set their position, and change their color.
So, I created 4 guides touching the 4 corners of the dress, then I used the Rectangle selection tool to select the inner area defined by the guides. Then I promoted that selection to a new layer, So now in the layers palette I had the promoted layer (along with the layer of the red dress). By selecting them both (the promoted layer first) I could use the Object->Align and Object->Make Same Size commands. The red dress probably had a slightly different aspect ratio though.. because it didn't align exactly. I had to slightly stretch it width-wise with the Pick tool.
Greetings!
"The red dress probably had a slightly different aspect ratio though" - if you run through LeviFiction's history math in detail, it seems that PSP may not have scaled precisely:
1667/627 = 2.65869218501 (pre-scale AR)
1896/713 = 2.65918653576 (post-scale AR)
It's funny. When I think back on the real project, I DID finally give up on just scaling the color image and went to stretching x and y - on the assumption that this would end up the same as scaling. But, if PSP's scaling is not quite exact, this would explain why the pure-scale approach didn't work.
Thinking about it, PSP probably cannot scale precisely because it must quantize to whole pixels. Since it appears that the tool does destructive scaling, this means that the AR is probably distorted with every scaling, and the errors add up.
Paul
