lata wrote:DotsFar wrote:Hello,
New user of VideoStudio 2020 Pro.
Have a small video in 4 parts, after cutting out sections. Have inserted Flip transitions in the 3 cuts.
Video and transitions plays perfectly in the editor and on the Share page, but after rendering, the file saved to disk misses 1 - 2 of the transitions, seems to be a bit random which one goes missing,
and the clean cut of the video is shown instead.
Why is this, does anyone know
when we add a transition it can be added over two clips causing the clips to overlap by the duration of the transition, the transition affecting both clips
We can also add to the end of one clip
Adding a transition to the end of the first clip will effect that clip the second will show without the transition, is that what you mean by "and the clean cut of the video is shown instead."
Are you able to create the same problem using the Solid Colour clips from the library
Then Zip and attach the project file (vsp) to your reply
The transition is added to both clips, as the dialogue says to hold CTRL to add to one only, and we don't do that.
I tried to reproduce with replacing clips with solid colour, but then it worked.
Back to Flip transitions, I now get this error during rendering
It seems to be highly dependent on the rendering type. Some terminate during rendering without errors, some gives errors, some says successful (but with some transition missing), and AVI is actually successful but with lousy quality
Edit: and AVC 1449x1080, 30p, 18Mbps also worked. Not sure how compatible the .m2t file is though.
