Hello,
I have been working with a video camera and I found out how to get it on the computer fairly easy using the usb cord, though IEEE would probably be faster transferring?
Though the problem is when I render to a mp4 file to place on facebook, it gives me the 360 version (and a headache)
When I play in VS2020 the project is fine, until rendered. I thought it was Facebook, but when I play the clip on the computer I get the same thing.
The project properties are, which seems ok? I checked under the 360 settings and nothing is checked?
So apparently I am either doing something wrong when recorded or when I render the project?
I believe that the camcorder initially records in mpeg2, could that be the problem when it converts to mpeg4? Thanks Bruce
NTSC drop frame (29.97 fps)
MPEG-4 Files
24 bits, 1280 x 640, 29.97 fps
Frame-based
H.264 High Profile Video: 5000 Kbps
44100 Hz, 16 Bit, Stereo
MPEG AAC Audio: 128 Kbps
video project when rendered is 360 Degree
